Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-12-2002, 04:16 PM   #1
Les Gilliam's Avatar
Profile:
AC Outlet Analyser
Just thought I would let everyone know that Radio Shack is having a clearance sale on their AC-Outlet Analysers. They normally sell for $5.98, but while they last they are going for 98 cents each. They are great for checking the campsite AC before hooking up your shore power.
Les
Les Gilliam is offline   Reply With Quote
Old 11-12-2002, 04:53 PM   #2
Zed2's Avatar
Profile:  1986 25' Sovereign
1965 17' Caravel
Plano , Texas
Do you have the part number?
Keith
Zed2 is offline   Reply With Quote
Old 11-12-2002, 07:29 PM   #3
Profile:
Hi Keith,
The receipt I have shows "AC Outlet Tester" and a number 2200101. The container which it came in has a number 22-101B on it. I am not sure which is the part number, but I suspect it is the latter. In he store where I bought mine, it was in the same rack as the mult-meters.
Les
Old 11-14-2002, 06:39 PM   #4
GA Airstreamer Air_005
Profile:  North , Georgia
Send a message via Yahoo to ALANSD
Thanks for that info, I was just looking to buy one of these.
Also how about a question from one with limited electrical experience- when I use my digital volt tester what settings should it be on for testing dc outlets in the coach, and ac also?
If I probe the dc outlets , I get a reading of what seems
way higher than 12v when on shore power. Lights and all seem to be working ok, but I want to be sure of the reading for voltage
If it is not right that indicates a problem with the univolt?
Old 11-14-2002, 06:46 PM   #5
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
alan,
what do you have for a meter? what are the settings available?
john
Old 11-14-2002, 07:07 PM   #6
I have an elktro-tek digital
Settings are 600 or 200 V~
600 200 20 2 V-...
mA 200m 20m 2m
or the ohm sign side=
20m 2m 200k
20k 2k/> 200/>
probes plug into com and V ohm M A or 10A
I am somewhat clueless on this and the manual might as well be in chinese.
However I am willing to learn
Old 11-14-2002, 07:21 PM   #7
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
alan,
~ equals a.c. voltages, i.e. your shore power
- equals d.c. voltages, i.e. your 12v circuits, batterys in general.
connect to com.(black lead) and v(red lead) terminals with your probes. avoid the 10a terminal as this is used to connect your meter in series with a circuit(you will never use it unless your trouble shooting a circuit board)
the 20 200 600 denotes voltage. you will notice the decimal point moves between 20 and 200.
what are the "strange" readings you are getting on shore power?
john
Old 11-14-2002, 07:34 PM   #8
evidently the strange thing is how I have been using the meter, I will try again now and see what happens.
Would you plug the two probes right into an ac outlet to check it?
What alerted me to a problem in the making was-
My tv/vcr has been acting up these past few days, the tv works, but vcr won't and the power light flashes...but now it is also doing that when plugged in my house as well, so I think the motorhome is ok and the tv is screwed. Thanks for the help, I will post again after I check voltage again.
Old 11-14-2002, 07:52 PM   #9
Retired Moderator
john hd's Avatar
madison , Wisconsin
Images: 40
modern outlets?
yes you would put both probes in the outlet, if you are testing modern outlets put the black probe in the left side. then the red one goes in the right.
to test the outlet for proper polarity, take the red lead and insert it into the ground hole. you should get zero volts. then move the black to the ground and take the red and check both sides of the outlet you should only have voltage on the right side.
if you have 120v on the left the out let is wired backwards.
of couse this is assuming you are looking at it like this.
I i
the left side should always have a larger slot.
john
Old 11-15-2002, 09:04 AM   #10
Thanks again- basic info for some of us is a good thing.
It is amazing how bad the manual for my meter is.
AC Gasket replacement Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2003 10:07 AM
Running AC question... Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 8 09-12-2003 09:53 AM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 11:38 AM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 03:04 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 12:01 PM
