Old 03-10-2004, 01:29 PM   #1
AC/DC etc., ect.
NEWBIE ALERT!
Sorry for a possible redundant thread, but. . .
I just bought a '61 Safari.
Are all of the interior lights supposed to be 12 volt? Are the wall sockets the only AC inside? Some lights are AC and some are 12 volt in this trailer.
Seems to me that it would be best to have all lighting to be 12 volt off of a battery then worry about charging the battery.
Marlboro Mafia is offline   Reply With Quote
Old 03-10-2004, 01:31 PM   #2
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
Welcome
Welcome!
My '67 has all lights on 12 volt and all outlets on 120.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 03-10-2004, 01:37 PM   #3
That's what I thought. It makes more sense.
Old 03-10-2004, 01:39 PM   #4
Images: 59
AC/DC both?
All the lights and the furnace in my '59 are both AC/DC
markdoane is online now   Reply With Quote
Old 03-10-2004, 03:28 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
AC/DC etc., ect.
The lights didn't go to strictly 12-volt until the Univolt became a standard feature in 1964. Prior to that most lights in a coach were dual powered - - separate bulbs for AC and 12-Volt - - and some were separate fixtures. In fact, if your coach has its original fans in the roof vents and the original furnace blower motor, you will likely find that there are small transformers that allow those devices to operate in their native DC (there is confusion in my notes on this point as I have written 18-Volt AC is the output of these transformers) environment when connected to shore power - - this might also apply to an original water pump as well, but that is a point that I haven't heard mentioned.
Kevin
Kevin D. Allen
AIR #827
Old 04-04-2004, 10:45 AM   #6
Crossville
Rivet 64 Bambi II - electrical system
I have analyzed the electrical system of my '64 Bambi II and have one "mystery" yet to solve...
First what I have found: All the interior lights are 12V DC when on battery, 12V AC when on "city power". There do not appear to be any 110V lights. The water pump is 12V DC only. There is no fan as near as I can tell, or it was removed by an earlier owner. The furnace did not have a blower. There is a 12V power/charging circuit from the trailer hitch wiring (Blue wire). (The refrigerator was propane only.)
There is a 2 switch panel which switches the lights and water pump to either "city" or battery power. This panel has automatic reset overload breakers.
Feeding this switch panel for "city power" there is a large transformer which produces 12V AC for the lights, and 19V AC which should run to a rectifier to be converted to 12V DC, for the water pump and battery recharge, and indeed the wire goes into the wall. As there is no 12VDC power produced (the water pump does not get power when switched to "city power" as it should) I am assuming the rectifier is bad. I also don't think it is a simple silicon diode bridge because these were not yet common at that time, or it would 1) not have required such a large voltage drop and 2) would have been mounted on the 2 switch panel.
The mystery is WHERE is the device located where the 19V transformer output goes.
I have drawn up a schematic of the electrical system, which I will post when I get it done in a computer readable format.
In the mean time, if someone can confirm what I suspect about the rectifier, and suggest where I can find it, I would be most greatful.
bothbobs is offline   Reply With Quote
Old 04-04-2004, 10:53 AM   #7
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I am unsure as to the output side of the 19 VAC but I have a guess. I would bet it went to the battery. The DC battery would act as a load and would reduce if not eliminate the AC waveform since it cannot be changed to an AC output. I think the old pump in your model would have been a Grover Air pump to pressurize the tank. Who knows how sensitive to the AC noise the motor would have been.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 04-04-2004, 01:06 PM   #8
We have a '61 Safari. I am new to the hobby, it seems that there is a lot to learn and no two trailers are alike. Our trailer has two seperate electric systems. Every light fixture has two bulbs and two switches. One 110vac and one 12v. All the wall outlets are 110v. It seems that the battery charger is missing. I am try to decide if I should add a charger or get an inverter/charger combo. It also looks like some reworking of the electric is in order, because it appears to have been hacked a few times. This trailer will keep me busy for a while.
Rick
Rick Dotson is offline   Reply With Quote
Old 04-04-2004, 04:02 PM   #9
RivetED's Avatar
North Central , USA
Originally Posted by Rick Dotson
We have a '61 Safari. I am new to the hobby, it seems that there is a lot to learn and no two trailers are alike. ...This trailer will keep me busy for a while. Rick
Welcome Rick, Keeping busy is what this hobby is all about for most (I guess ). Even with a new '04 I'll bet my 'to-do' list is a lot longer than you'd think. Anyway; keep busy, have fun, send & receive tips, post your trials & tribulations, & perhaps we'll see you down the road & share a cold beer or two! .
RivetED is offline   Reply With Quote
Old 04-04-2004, 04:05 PM   #10
Who knows we might be traveling to Colo. this year and see you on the way. Or maybe you drive east? (I don't know what for).
I will try to post anything that I find out.
Rick
Old 04-04-2004, 06:10 PM   #11
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Rick -
Does that mean you're planning on attending the VAC Rocky Mtn. Rally at the end of July/beg. of Aug. in Colorado Springs? There's still some room left if you hurry.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is online now   Reply With Quote
Old 04-04-2004, 06:12 PM   #12
Actually we were planning to visit some friends who moved to Denver. We had not thought of attending any rallies. Although It might help set a date for the trip.
We were thinking to go to S. Dakota as well.
Old 04-04-2004, 06:29 PM   #13
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
S. Dakota is beautiful, Especially the western part. Check out Deadwood, Wind Cave, the Badlands, Wall Drug, Custer State Park, Bridal Veil Falls...that does it, I want to go right now
FF
Old 04-04-2004, 07:05 PM   #14
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Marlboro Mafia: Does your 1961 Safari have a "Land Yacht" plaque riveted to the outside forward of the door? Does it have a small battery compartment on the front panel of the trailer? If yes, then it has a dual voltage system of separate 12 vdc and 115 vac circuits for lights. The 12 vdc circuit used regular size (same size as 115 vac) light bulbs that were 12 vdc. Battery charging was from the tow vehicle. You should be able to wire a modern converter having a smart 3 stage battery charger into your 12 vdc circuit. I like IntelliPowers for that job.
BothBobs: In 1964 only, the first year for the Univolt as Kevin mentions above, it was a simple AC transformer with two outputs: 12 volts AC for all lights and 18/19 volts AC for the fan (which you trailer apparently does hot have) and for the original PAR [Peters and Russel, mfgrs] water pump. If your present water pump is marked for 12 vdc only, it is likely a more modern replacement water pump. In my 1964 19' Globe Trotter, I replaced the ac only Univolt transformer with a 40 amp IntelliPower converter and Charge Wizard that keep the battery charged when the trailer is plugged in, which is all the time because I store it at my house. I really like the IntelliPower converter/battery charger.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
