Old 08-07-2014, 09:13 AM   #1
2014 27' FB International
Santa Rosa , California
Cool AC and Micro Triping Breaker
We have a 28' Int'l. The 20A breaker keeps triping when micro/convection is on. Are there alternate wiring schemes or larger breaker solutions? Thanks
NatandGregg is offline   Reply With Quote
Old 08-07-2014, 09:25 AM   #2
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
According to the dometic website, the 15k A/C draws about 3a for the fan and 13a for the compressor. I don't know the starting amperage but given the breaker, it can't be beyond 20. In my 2011 international, the micro-convection draws about 8 amps. So, yes - I would assume running the two at once would trip the breaker. My worry (for the experts) is if the micro convection is in use; and then the A/C attempts to start, could the low amperage available cause compressor damage?
I already assume not to run anything else along with the A/C - I'll even be sure to switch my fridge and water heater to propane if I know I intend to use the unit.
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 08-07-2014, 09:38 AM   #3
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
I guess my first question is to what power source are you connected? Generator or land based electrical? Since the A/C and the micro are on separate circuits, I'd be suspicious of the source of power to the trailer. While the electrical panel could fit a larger circuit breaker, you cannot safely do so without upgrading the wiring to that breaker.
For example, when connected to 30 amp grid supplied power (like at a RV park), I can run both A/C and the micro. When connected to my twin Yamaha 2000's, I can run one or the other but not both.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 08-07-2014, 11:02 PM   #4
Solution
I have also checked with the factory and they confirmed that running both (off generator) micro/AC was not advisable. I am considering upgrading to 50 A, similar to the Land Yacht install. I got the specs from the factory and have asked for a quote from the dealer. Thoughts?
Micro Pulse Tank monitor calibration Silvertwinkie Plumbing - Systems & Fixtures 98 11-03-2014 01:09 PM
Breaker, Breaker!! Bing-Bing Generators & Solar Power 25 09-24-2013 08:25 PM
breaker breaker project66 Batteries, Univolts, Converters & Inverters 4 05-29-2012 08:37 PM
Plug fridge and micro in same outlet? pamelake Refrigerators 17 09-04-2007 05:41 PM
micro wave light wb13798 Airstream Motorhome Forums 2 06-24-2005 08:24 PM
