If the second connection was such a great idea for the units with 30 amp service, why did Airstream not offer that option for 50 amp service?
A 50' Furrion 50 amp power cord is over $480.00. The cost of a double pole double throw relay, plug socket and thirty feet of #6 triplex wire with ground would be much less than that and would have put the generator noise at the opposite end from the bedroom for most 30'+ models.
The gotcha is a 50 amp switch starts to cost real money and requires quality relays, not electronic relays that are cheap.
