Old 10-20-2008, 01:56 PM   #15
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Mite have bought the wrong tach.
ISSPRO.com Your home for quality Gauges, Tachometers, Speedometers, and more!
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-20-2008, 03:28 PM   #16
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This may help you as well:
Tiny-Tach: Diesel Tachometers#
Old 10-20-2008, 05:17 PM   #17
1982 28' Airstream 280
Buena Park , California
We have bought a brand new teleflex tach to replace the one that blew due to an unrelated issue.
What we to know is where the tach send post gets it pulse. Is it from the field stator, regulator, what?
also, we would like to know what regulator brand you have for a similar model and the color code to the 6 wire plug both on the regulator side and harness side.
kennytheecat is offline   Reply With Quote
Old 10-20-2008, 05:40 PM   #18
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Who are "we"?
Keep in mind that this forum is a bunch of enthusiasts who like to help people where possible.
I personally don't like the tone of your last post. Everyone tried hard to help you. It would be best for you, at this point, to go buy a manual with a schematic.
Tom
Old 10-20-2008, 05:49 PM   #19
sorry Tom. No tone was intended. I and my father in law (we) thought it was along shot for someone to help us with this problem, but would give it a try and so far the responses have been great. Truly, i am nothing but exstatic with the help I have so far received. I thought i needed to be more specific and clear. Please forgive me for any offputting tone.
Old 10-20-2008, 06:03 PM   #20
Mike Leary's Avatar
Images: 11
You've got to understand we're all dunderheads and can go so far in troubleshooting; there are so many variables.
Old 10-20-2008, 07:28 PM   #21
2005 22' Interstate
Afton , Virginia
Most alternators have rectifier diodes that convert the ac generated by the alternator into DC that can be used in the battery charge circuit. The rectifier diodes operate off the rotor, as this is the unit that is driven by the crankshaft. Thus, the faster the crank spins, the higher the freq generated. This is what the tach must measure, if I get the drift of this thread.
One of the thread spinners (sorry) mentioned a manual. This is good advice.
regards
herrgirdner is offline   Reply With Quote
Old 10-22-2008, 04:13 PM   #22
Thanks for all the help. We got it figured out. Thank you. Thank you. Thank you.
One more question,
What rpm does your engine idle at?
Old 10-22-2008, 04:32 PM   #23
TomW's Avatar
1967 26' Overlander
Glad you figured it out.
What did you find out? It may help others.
Tom
Old 10-22-2008, 10:20 PM   #24
What we did was to trace all the regulator and alternator wires out and fixed any previous-owner wiring snafus. We found color coding changes hiding under electrician's tape and such. Example....yellow wire coming off of the alternator plug connected to a black wire and a black wire coming off of the alternator plug connected to a yellow wire all hiding with a layer of tape. Nightmare-ish.
We configured the six wires in the voltage regulator plug to match the engine manual wiring diagram. Our new, Echlin VR550 voltage regulator's plug is not configured the way the manual shows.
The pulse for the tach comes off of one of the stator phase windings. The stator is a wye, three phase stator. There is a wire connected to the output of one of the phase windings in the alternator harness. It was one of the color code switch-a-roo wires. This color code problem caused so much hair pulling, as you can imagine. We got good tach pulse signal, once we got the pulse wire sorted out.
The direct replacement Teleflex tach is a 54314D.
Three plus days chasing funky wiring issues.
Still have an apparent overcharge issue. Plan on getting that taken care of
tomorrow, Thursday.
Again, thanks to you all for your helpful input.
One of those nightmare days Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 08-21-2007 09:20 PM
Is My Dream a Nightmare? sierrajb Member Introductions 70 12-04-2006 09:07 AM
Nightmare at Inland RV 65gtross Our Community 25 11-12-2004 08:33 AM
Electrical Nightmare Repodog Electrical - Systems, Generators, Batteries & Solar 6 11-05-2003 04:53 PM
