Old 12-26-2018, 06:12 PM   #1
2017 19' International
Akron , Ohio
A/S In Heated Storage, Negative Disconnected
Looking for some guidance on periodic charging of dual batteries while my 19C is in heated winter storage. Have disconnected the negative but positives are still connected. Can I top up the charge on both batteries at the same time?
Jack
Oakknollpres is offline   Reply With Quote
Old 12-26-2018, 06:20 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
A stand-alone automatic charger is what I would use.
So long as the charger’s leads connect with their respective terminals on both batteries, all is fine.
A good automatic charger could be left on full time..
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 12-26-2018, 07:17 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Totally agree.
Look at the BatteryMinder 128 - it is designed to be connected to the battery bank 24/7, compensates for ambient temperature, delivers up to 2/4 or 8 amps depending on how many batteries you have in parallel, and periodically delivers desulfurization.
Will keep your batteries healthy.
wulfraat is offline   Reply With Quote
Old 12-26-2018, 07:20 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
Yes...Connect and use your converter when the voltage drops to 12.4v
Yes...with a standalone charger,(not a maintainer), connected in the AS, + on one batteries + post, - on the second batteries - post.
If using a maintainer...Make sure the batteries are fully charged and leave it on 24/7
I've used both methods but preferred the first, made little sense not to use the AS's converter, as our AS is on the home pad with 30a ac.
Even with the AS supplied converters, if only charged when needed and checked regularly you won't have a problem.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-07-2019, 08:34 PM   #5
waninae39's Avatar
2017 22' Sport
NCR , Ontario
best to disconnect the -ve lead
BTW, we took out the Lion battery this winter and installed the old lead acid battery so that we can work on and monitor the As over winter
it has been cool the last few weeks
Name:	battery temps.JPG
waninae39 is offline   Reply With Quote
Winter Storage - Indoor and Heated akstrm Winterizing, Storage, Carports & Covers 20 10-09-2013 12:30 PM
Winterizing Argosy Minuet with heater disconnected ArgosyMinuet All Argosy Trailers 1 10-15-2010 10:48 AM
What is disconnected wire used for? airfoil Batteries, Univolts, Converters & Inverters 1 08-04-2009 10:47 AM
disconnected duct boondockdad Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2007 05:26 PM
Disconnected Battery while driving Dan S All Argosy Trailers 8 08-07-2007 12:01 PM
