A reset battery
As many of you know, Airstream march's to their own drummer, and to hell with the rest of the RV World.
Case in point;
The two batteries are mounted in the same orientation, requiring removal of a lot of connection wiring, so that one may access the curbside battery to check the water level, and the specific gravity. [ATTACH]280364[ATTACH]see atttached photos. One is the OEM installation, the other is after I switched one around.
As you can see, the curbside battery caps are now accessible.
I also wrapped spiwrap around the cables where they could chafe, and short out in the future.
Look after your equipment, it will look after you.
Trailer Trash...........
