Old 09-04-2005, 04:43 PM   #1
Westfalia's Avatar
Some Place with a German Name , Texas
Images: 35
Send a message via AIM to Westfalia
A new kind of quick connect 12V outlet
Devoman came across an interesting plug. It's called a MagCode. It's a keyed flat plug with magnetic hold, waterproof, 15A, a low depth mounting.
http://www.magcode.com/english/power.html
These would make excellent external speaker jacks, or auxiliary power ports to external lights.
What do you guys think? What would you do with such a plug?
Westfalia is offline   Reply With Quote
Old 09-04-2005, 05:34 PM   #2
Tinsel Loaf's Avatar
Personally I really don't see much of an advantage over the exsisting technology of providing 12 volt power. Rather than plugging you twist, and over time those contacts will corrode overheat and arc just like the differnt plugs and jacks we have today. I have seen similar contact connectors in the past like finger springs that failed over time just from passing DC current.
Some of the best and greatest ideas never made it in the market place just because the idea was way ahead of it's time. We will have to wait and see how the public excepts it.
Tinsel Loaf is offline   Reply With Quote
Old 09-04-2005, 06:22 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I believe those plugs are already in use in some industries. It looks a lot like the plugs on commercial power meters that they use for attaching a laptop to for readings and programing. Maybe johnhd might have some info on this.
Aaron
WBCCI #XXXX AIR #2495
Old 09-04-2005, 06:26 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
aaron
those are optical.
what would be wrong with a good old fashiond 1/4 inch phono plug and jack for a set of outside speakers?
with a weatherproof cover of course!
john
you call them ferrets, i call them weasels.
12v
12V question uwe Electrical - Systems, Generators, Batteries & Solar 16 09-05-2002 01:14 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
waterhose quick disconnects John Fresh Water Systems 3 04-19-2002 06:58 PM
