Old 11-26-2012, 07:45 PM   #1
1970 23' Safari
Waterville , Iowa
A/C wiring
Have a 70 23 ft safari in the shop right now customer wants a/c put on need a/c power up to the center roof vent. 3 of the four breakers are used. the one to the far right is empty which I believe was used for ac there is a wire in there that is not used that appears to head up. Was this pre wired for A/c and if so where do they run it to
fritzm1369 is offline   Reply With Quote
Old 11-26-2012, 09:01 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
There should be prewire up there. Andy at Inland RV can tell you the strut number where the wire would be located as he has a book with that in it. Give him a call.
Old 11-27-2012, 03:24 PM   #3
1970 23' Safari
Waterville , Iowa
There is always someone out there that knows more about something than I do . Very glad to have the help
2nd A/C for a 34' - 2002 Classic HighFlying 2001 - 2005 Classic 10 11-17-2011 07:04 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
A/C and wiring question Hoosierdaddy Furnaces, Heaters, Fireplaces & Air Conditioning 20 08-20-2011 06:15 AM
1991 Excella 1000 - New Radio need wiring help! jbbaldwin Audio, Video & TV 0 07-13-2011 12:04 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
