Old 08-08-2012, 01:42 PM   #1
Hawk43's Avatar
1999 30' Excella 1000
Graford , Texas
A/C pops CB
I have a 30 ft. 1999 Excella. The A/C pops the 20 amp CB after about 30 minutes of use when the outside temp is in the high 90's or 100's It is a brand new Dometic 15K BTU. The old 13.5K BTU was doing the same thing. Any thoughts?
Skip Dent
Hawk43 is offline   Reply With Quote
Old 08-08-2012, 01:51 PM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Yep, same AS, same problem. It appears the breaker gets hot and blows. We open the front of the breaker box, take off that plate, and have an inexpensive clip-on fan mounted to the open overhead storage door pointing at the breakers. That has seemed to keep the breakers cool enough to hold.
I was told by Terry at ODM that the old 13.5 compressor was failing, and that caused the blow. I had them install a new 15. It is quieter, and seems to work more efficiently. Still, when the inside of the AS is very hot we need our fan arrangement to get it down to cool enough. Once the inside is cooled down the breaker seems to hold.
Hope this helps.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 08-08-2012, 02:15 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Breakers are easy to change and new ones are inexpensive.
Vaughan
Old 08-08-2012, 02:26 PM   #4
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
And those "miniature" breakers seem to be more susceptible to heat. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 08-08-2012, 03:27 PM   #5
1983 34' Excella
1967 24' Tradewind
Images: 32
Agreed.
The originals in my trailers got hot. Not an issue after replacement.
Vaughan
Old 08-08-2012, 05:13 PM   #6
richinny's Avatar
2011 34' Classic
http://www.airforums.com/forums/f37/...red-80909.html
could post #10 be your situation?
Ricky
