I have had similar problems to those described by Al - both on the circuit board of the thermostat (whitish corrosion cleaned with alcohol and q-tips) and also with the pesky telephone type connectors both at the circuit board and under the interior AC grille.
They can do screwy things with the AC!
I just fiddle with them plugging /unplugging+ contact cleaner and (so far) eventually, it all works - until next time! It is truly a pain. Not sure these connectors are best suited for this application! There are similar phone type connections up to onto the AC control board -I have not cleaned those yet but probably I should as they are likely in a worse environment.
Incidentally, those cables look like standard telephone cables, but they are not - the actual connectors are the same, but at one end of the cable, , the connector needs to be reversed.
Lewster on this forum put me wise to this and it is confirmed in the Dometic manual. Just in case you decide to change a cable!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
