Old 07-07-2012, 03:42 PM   #29
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
Originally Posted by redwoodguy
Great ending! Dog gone reset button!
Yes indeed ... and I'll never forget that little button exists again!!!
UAPachyderm is offline   Reply With Quote
Old 07-07-2012, 05:57 PM   #30
1988 32' Excella
Robbinsville , New Jersey
Wow lots of ambition in the heat. Once bypassed and working I would have left it bypassed until it cooled off.
Old 07-09-2012, 04:26 AM   #31
Originally Posted by CrawfordGene
How did the reset breaker on the inverter trip?
Gene
Well, it seems that this is still a question I don't know the answer to. Friday, the breaker on the inverter coming in from shore power tripped. All was well until Sunday evening.
At least twice Sunday night power went out and back on ... without tripping any breaker.
About 4am this morning the breaker on the site pole tripped. I inspected everything then reestablished power on the site pole.
A few minutes later the site pole breaker tripped again. However, this time I saw a small "flash" at my old converter. Oddly, nothing is wrong inside the Airstream (no bad fuses or tripped breakers) ... but the breaker on the site pole is tripped.
I tested the site pole and it appears to be in good order. I had maintenance come over and they said pole appeared good. However, I am not taking any chances and plan to change sites to be sure the problem isn't a surge issue from this site. I'm at Disney Fort Wilderness ... they are sending over their Forman of electricians at 8am.
Interestingly, when I turn my inverter on, everything works. So, I'm still having issues getting shore power and the cause is a mystery.
Perhaps it is the site. Could be I didn't reconnect everything super tight (double checking all that now). Could be my inverter as originally thought (it's been squirly since install and Lew and I have wondered if it had a bad board/relay). Perhaps it is some issue I haven't thought about yet.
Not hot here this Monday morning ... yet ...
Old 07-09-2012, 05:48 AM   #32
No m
Old 07-09-2012, 06:55 AM   #33
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
Glad things worked out,..little late reading here.
On the subject of running things,..we run our convection microwave,A/C, Television and charge our iPads and phones and turn the lights on and off At the same time,..and have never had any problems.
Are we asking for trouble?
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 07-09-2012, 06:59 AM   #34
Shane
They say not to do it. We've never ha issues until I added an inverter.
Old 07-09-2012, 07:01 AM   #35
BTW, the breaker on site was on the fritz. It's been replaced (my situation may have caused it to go or it may have caused my situation ... who knows). We are back up and running. Hopefully it stays that way!
Old 07-09-2012, 07:27 AM   #36
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by CrawfordGene View Post
How did the reset breaker on the inverter trip? Was your wife using too many things while operating on batteries and inverter? It sounded like you were on shore power, but maybe 120 v. shore power is routed though the inverter and it would trip the breaker there instead of the converter main breaker.
Gene
My supposition is that since the inverter has an automatic switchover from 30A shore power to inverter power, it has a 30A breaker to protect that circuit (fits with the label on that button). It seems that the inverter's breaker is a little more sensitive than the trailer's main breaker.
UAPachyderm: Is that breaker inaccessible when the inverter is installed? Or just hidden from view?
David
Old 07-09-2012, 02:37 PM   #37
Accessible ... just not in plain view. LOL, no worries, there's an obvious label and arrow on top now!
Old 07-10-2012, 09:02 AM   #38
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Double diagnosis is a bad approach to problem solving, but sometimes 2 things do go bad.
It sure sounds like:
1. The campground breaker was bad, and
2. The inverter has a pre-existing condition.
Even if the new campground breaker is fine, the inverter may still need a new circuit board. If the company will send you a replacement without asking you return the inverter, I'd go for it.
Gene
Old 07-10-2012, 02:03 PM   #39
Gene
Yep, the plan is to replace the circuit board upon return.
Old 07-10-2012, 02:39 PM   #40
Master of Universe
Gene's Avatar
Cool, literally.
Gene
Old 07-10-2012, 09:03 PM   #41
mefly2's Avatar
2015 25' FB Eddie Bauer
Would a line conditioner / surge protector be a good idea to have upstream ... between the power pole tap and the AS power connector plug in this case; or, would it just compound the issues? I have seen some that advise of proper polarity as well as over and under voltage. I know that they are not inexpensive, but if it saves replacing a board in the inverter ... ???
