Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-21-2008, 10:52 AM   #1
Yankee Jukebox Shop
Profile:  1966 22' Safari
1979 30' Argosy
1974 31' Excella 500
Winchester , New Hampshire
79 Argosy 30 center bath WIRING DIAGRAM
Hi All, Might anyone have a wiring schematic for my 79 Argosy 30 with center bath? I seem to have a lack of 110v and can't easily trace the wiring. Also, believe it or not, this thing has no gauge panel. The holding tanks have harness plugs all neatly coiled up, but not connected, and there's absolutely no evidence of a gauge panel. Thanks in advance!
mrjukebox is offline   Reply With Quote
Old 04-21-2008, 01:53 PM   #2
Silverhobby's Avatar
Profile:  1964 17' Bambi II
1956 26' Cruiser Overlander
1957 26' Overlander
Vale , North Carolina
Hi mrjukebox, My 1979 Argosy 30 A does not have a guage panel either. That was an upgrade option.
The 120 volt enters the trailer thru the rear of the trailer at the circuit breaker panel. Then ac current goes to the polarity light, then the Univolt receptacle. Next, it goes to a rear bedroom receptacle, a forward bedroom receptacle, the bath receptacle, the exterior outlet, the refrigerator outlet, the galley (kitchen outlet), then to the forward outlet near the front streetside (in living area.)
Hope this helps. The other circuit is for the air conditioner.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 04-21-2008, 05:57 PM   #3
Yankee Jukebox Shop
1979 30' Argosy
Thanks, found the problem with the 110. Someone had screwed with the wiring as it entered the fuse panel, and while the AC worked, they had the outlet circuit wired so both the black AND white wires were ganged to the breaker! Thus I had no netural leg and no power at the plugs. I thought I'd have to rip the entire thing apart. Goes to show you that start where stupid people have been and you'll usually fix everything. I'm glad I did some ripping open though, I found that the same wire from the circuit panel had been gnawed to bare on all leads just behind the wall where the breaker box mounts, but if I hadn't opened the wall and peeked inside, I never would have seen the problem. Thanks for your help!
Oh yea, so if the panel was an "upgrade option" is there a reasonable way to retrofit such a panel now? I figured I'd ask rather than reinvent the wheel.
Chris
Pingbacks are On
'72 Argosy 22 - 12v wiring diagram nm_mike Electrical - Systems, Generators, Batteries & Solar 1 09-27-2007 03:39 PM
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
1975 Argosy Need wiring diagram to repair directional lights, etc. Rt66Argosy Member Introductions 2 09-27-2006 09:51 AM
Preference: Rear or Center Bath? Navigator General Interior Topics 28 03-11-2004 07:45 AM
plumbing diagram for rear bath maznblu Fresh Water Systems 1 06-18-2002 09:00 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
