Old 02-26-2008, 06:17 PM   #1
Robin Stone's Avatar
1977 31' Excella 500
Gastonia , North Carolina
Question 77 Excella Switch and Plug
Hey Everybody,
I ran across a switch which I have no idea what it is for , also there is a plug in module coming out of a hole where it looks like this switch may go.
The hole missing the switch is all the way forward on the curb side just above the porch light switch.
If any one could give me a clue I sure would appreciate it. I looked at the maual but it is kind of confusing , because they are showing an international also.
Robin Stone
ID:	55154   Click image for larger version
ID:	55156   Click image for larger version
Robin Stone is offline   Reply With Quote
Old 02-26-2008, 06:26 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Auto Skyliner was an optional electric TV antenna. It can raise, lower and turn the antenna from that panel. It is missing the 4 amp fuse.
Richard
Old 02-26-2008, 06:26 PM   #3
DPeakMD's Avatar
1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Send a message via Yahoo to DPeakMD
You've uncovered one of the Excella 500 upgrades from this late 70's era! It's a motorized TV antenna. The switch was used to raise/lower and rotate the antenna. From what I've heard, the outside parts of the antenna were failure prone. We still have a control panel in our '78XLA500 the antenna was replaced with a manual Braud Skyliner.
Dallas Peak, MD 'That 70's Guy!'
VAC 1VP President
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 02-29-2008, 07:43 PM   #4
Switch and plug
Thanks Richard and Dallas , I probably would have never known what that switch was with out your reply. I believe the PO has already put up a manual antenna , and it's already stuck.
Does anyone else might know where or what that harness goes to ?
I'm thinking it may have something to do with the stereo which is also missing.
Any help is appreciated.
Thanks Again,
Robin Stone
Old 03-01-2008, 04:47 PM   #5
Please don't any body answer that last question , sometimes I'm so crazy I amaze myself.
After I got to checking I saw where tht plug went into that switch , I also pryed the tambour back on the front left side and dicovered where the stereo connections were.
Robin Stone
'89 Excella 25 mystery switch? Pix attached also... BillTex 1987 - 1989 Excella 12 05-22-2011 01:05 PM
Help with Pollak plug Uncle Jack Hitches, Couplers & Balls 4 04-28-2007 09:32 AM
wall switch in Excella 1990 32' femuse Electrical - Systems, Generators, Batteries & Solar 3 03-09-2003 11:34 AM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
