Old 11-23-2017, 07:01 PM   #1
Fin4's Avatar
Bailey , Colorado
76 Argosy Motorhome Generator
Hi I just purchased a 76 Argosy Motorhome. I looked everywhere for a owners manual however I was unable to locate one. There is an original working Onan generator connected to the vehicle. I can turn it on via my ignition key when starting the vehicle. I'm wondering how to use the generator to power a tv or fan when not connected to shore power. I have never used it and do not have a clue how to start it from inside the vehicle and where to plug the load into. I was also wondering if the generator needs routine oil replacement and where to fill the oil on the generator and how often (2 cycle or ?). Are there any other routine maintenance the generator needs?
Fin4 is offline   Reply With Quote
Old 11-23-2017, 07:14 PM   #2
Undereducated AS Newbie
1989 34.5' Airstream 345
Charlotte , North Carolina
Find the tag with the GenSet info, Model Number, etc & add it so folks can give you some specific info re your questions.
wimpy is offline   Reply With Quote
Old 11-23-2017, 07:28 PM   #3
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 32
My 1975 20' Argosy MH (sold it this year) had an original working 4KW Onan generator. There was a switch on the control panel inside the MH that would start the generator. You could also start the generator using a switch that was located next the generator. The power cord for shore power was located in an outside compartment streetside in front of the rear wheels. Also inside that compartment was an electrical outlet that you could plug the power cord into. That outlet was connected to the generator, so that would power the MH using the generator. The power cord was either plugged into shore power or plugged into the generator outlet.
Rick--Foley RV Center www.airstreamofmississippi.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 11-23-2017, 07:39 PM   #4
Fin4's Avatar
Bailey , Colorado
It's a Onan 4.0 BF C3R /1600 2B generator.
Old 11-23-2017, 08:02 PM   #5
Fin4's Avatar
Bailey , Colorado
I located the control panel above the stove and the shore power box inside the rear wheel compartment. What of the oil and maintenance requirments?
Old 11-23-2017, 08:48 PM   #6
Onan GenSet Info
Found this Onan forum to be very helpful with issues I had with my 6.5
https://www.smokstak.com/forum/forumdisplay.php?f=6
Generator for my 20 foot Argosy motorhome mirobbi Electrical - Systems, Generators, Batteries & Solar 30 11-29-2018 10:16 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Argosy Trailer vs. Argosy Motorhome??? crabbey1 Argosy Motorhomes 6 01-23-2014 06:39 AM
1978 Argosy 24ft motorhome generator panel Tom Schmidt Argosy Motorhomes 0 02-22-2004 09:52 PM
