Old 08-05-2008, 08:38 AM   #1
1976 Argosy 24
Seattle , Washington
'76 Argosy Doesn't Take a Charge
I bought a new battery for my old (recently acquired) '76 Argosy 24. Installed it. However long I try to charge it up with my Honda generator, it takes no charge. My lights and electrical system runs beautifully off the generator. Am I not turning on an overall system switch somewhere (looked but cannot find) in order for the battery to charge? I suppose the "new" battery could also be dead? I have not tested it. I welcome any advice for a newbie. Particularly if I am overlooking some overall system switch.
Boardy is offline   Reply With Quote
Old 08-05-2008, 10:08 AM   #2
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
Just a thought... a new battery does not mean a "good" battery. I recommend that you test the battery outside of the trailer to see if it holds a charge otherwise. With electrical... start with the simplest solutions and work your way to the more complex.
hampstead38 is offline   Reply With Quote
Old 08-05-2008, 05:26 PM   #3
1976 Argosy 24
Will try your suggestion
Dear hampstead38,
I will check this next week and post again on the results. Appreciate your input. Welcome any other suggestions.
Paul
Old 08-05-2008, 06:58 PM   #4
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Are you charging via the Uni-volt (Converter-Charger in the trailer) or directly off the generator? If the former, is the battery disconnect switch turned to off? If the latter, do as Hampstead38 suggested. Take it to one of the BatteriesPlus or similar with good testing equipment and let them have a go at it, (4027 Tacoma Mall Blvd). Good luck, welcome, and let us know how you make out.
wil
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 08-06-2008, 12:28 PM   #5
1976 Argosy 24
Dear Wil,
Newbie response: I do not even know if I am charging via the Uni-volt charger in the trailer. I just have my generator hooked up to the rear external cord and expected that to be charging the battery.
Where would the battery disconnect switch be? This is probably the key - the solution. Again, '76 Argosy 24.
By the way, thanks for the Tacoma Mall Blvd. address.
Sincerely,
Paul
Old 08-07-2008, 11:02 AM   #6
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
Try looking around for a sort of hidden switch location. Mine is located behind the sofa on the cover over the battery box and the UniVolt and fuse block. They do get creative at the factory. ;
wil
AIR 22828
TAC ME-3
Latitude: 44.894663
Old 08-07-2008, 01:29 PM   #7
1976 24' Argosy 24
Milford , New Jersey
Boardy, we own a 76 Argosy 24, there is no battery cutoff switch installed from the factory that I know of. Someone may have installed one. You will really need a common Volt meter or multimeter to be able to test the battery and Univolt. I suggest you purchase one before proceeding. Check the battery as sugested and also check if the Univolt is charging. With the unit plugged into shore current see what amount of current is reaching the battery. Chechk the fuses in the univolt. One of them may be bad. Check to make sure the battery ground cable is connected. Good luck.
Gkiesel is offline   Reply With Quote
Old 08-07-2008, 01:33 PM   #8
1976 Argosy 24
Thanks to all
I will check accordingly. Will be able to check on Monday. Will report my findings. Thanks to all for their helpful advice.
Sincerely,
Boardy
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
Where's the Charge going The Flintstones Electrical - Systems, Generators, Batteries & Solar 2 09-29-2006 08:02 AM
Mechanics: What would you charge? Chuck Our Community 14 09-27-2006 05:44 PM
How do batts re-charge? frozen chosen Electrical - Systems, Generators, Batteries & Solar 8 10-27-2003 03:59 PM
Charge Wizard - Help! dmreilly10000 Electrical - Systems, Generators, Batteries & Solar 6 11-15-2002 03:37 PM
