Old 06-07-2008, 11:31 AM   #1
1975 31' Sovereign
Pensacola , Florida
75 31' Intl. Sov. univolt problems
Hello everyone. We have just purchased a 1975 31' rear bath and are ready to get started on refurbishing but ran into one problem. We plug our airstream into the wall (using the standard household type plug coming out of the rear storage) and run a couple of things through the electrical outlets (box fan, radio) and have the lights on. After doing that for a couple of hours our lights start flickering and getting VERY dim almost as if our battery is running down. I looked in the closet at where the fuse panel is and there's a 12 volt battery charger hooked into the fuse panel. I looked behind the wall and I do have a univolt there but I was wondering why someone would have a charger hooked to the fuse panel unless maybe the univolt isn't working. Is there anything I should try or does anyone out there have any similar problems or suggestions? Thanks for any help, like I said, my family and I are just starting on this venture.
RandyG is offline   Reply With Quote
Old 06-07-2008, 11:36 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I think you hit the nail on the head with this one. Most likely the univolt failed and the PO was charging the battery with a charger. I would start making plans to replace the univolt with a 3 stage converter and be done with it.
Richard
Old 06-07-2008, 12:14 PM   #3
1975 31' Sovereign
Pensacola , Florida
Thanks Richard. Do you have any recommendations at all on what I would need to get and where I should get it. I appreciate all your advice and help. Thanks
Randy
Old 06-07-2008, 02:03 PM   #4
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
I just ordered Intellipower 9200 models from Vintage Trailer Supply. Good price last week.
You'll also need a fuse block of some kind, if your Sovereign doesn't have one separate from the Univolt. Sometimes you can remove the fuse block that's in the Univolt and mount it on standoffs. Otherwise, fuse blocks are $17-35. I recommend that if you do get a new fuse block, get one that uses the standard size automotive fuses. These come in sizes from 3-40 amps. I haven't found a need for anything more than 40. Some members will say you need 60 amps for the batteries, which might be theoretically true, but not in practice, unless to totally flatten a battery (bad, bad practice. always leave at least 20% charge on a lead-acid battery).
If your new fuse block uses automotive fuses, you don't need a battery switch--just pull the appropriate fuse(s). That'll save you $20 right there.
Also, I don't fuse both leads from the battery, just the positive lead. There are some remotely possible failures (battery + lead insulation breaking down and shorting to the shell) that a negative lead fuse will protect you from, but they are so improbable that in my judgment the second fuse is a total waste.
Zep
Old 06-07-2008, 03:51 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Randy (68overlander on the forums) also sells converters for our trailers. I got ours from him, and have been very happy both with price and customer service. He has a website for his place also, BestConverter - Converters, Inverters, Electrical Supplies, Electronics.
Old 06-07-2008, 05:07 PM   #6
Dan@LED4RV's Avatar
Denton , North Carolina
Here is a link to how install the new converter and panel.
Airstream Converter Change-over
Dan
Dan@LED4RV is offline   Reply With Quote
battery charging, electrical, lights dimming, univolt
What did the '77 31' Sovereign Intl LI Pets 1974 - 1979 Sovereign 5 10-15-2015 02:55 AM
12v & 110 1969 Sov 31' CJ of Okla Electrical - Systems, Generators, Batteries & Solar 3 10-02-2007 10:50 AM
Replacing a Univolt in a 31' International wacnstac Electrical - Systems, Generators, Batteries & Solar 9 09-07-2006 09:39 AM
Our 1977 31' Sov. Midbath Marvel klayman Member Introductions 2 05-27-2006 07:15 AM
'69 Soverign Univolt Problems? rock Batteries, Univolts, Converters & Inverters 11 08-23-2005 06:02 PM
