Old 05-30-2010, 07:54 AM   #1
1974 31' Excella 500
North Bend , Washington
74' Excella, to remove wiring or not to remove?
I'm in the middle of a full on restoration of a 74' Excella, and was wondering about the pros and cons of removing the wiring "harness" . The reason I'm thinking of removing it is so I can give the interior of the shell a through cleaning (there is a bunch of mouse droppings and I want to be able to see where I might need to replace any sealant), clean up the wires, and check for any faulty or damaged wires. If I do remove it I intend to mark all the wires and keep a detailed record that includes pictures.
My concern is that if I remove it I would cause some damage to the wiring that could potentially lead to a bunch of extra work. Any input or suggestions would be appreciated, thank you for your time.
Will
BaltiHimal is offline   Reply With Quote
Old 05-30-2010, 08:27 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I would remove the inner wall skins and inspect the 12v and 110v wiring. If it looks faulty or worn, replace it.
While you have the skins off, I would inspect the insulation and do some cleaning.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-30-2010, 09:32 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We removed the wiring harness, and everything else for that matter, in our refurb project. I was a bit concerned about the age of the wires, and potential critter damage, plus the cleaning of the inside was a lot more thorough without the wires in way. The final deciding factor was we're going to move the location of the converter, and I wanted to add more 110 VAC circuits and outlets, as well as some additional 12 volt circuits. If you're going to re-do it all as original, then keep good notes on what you remove. If you're going to add circuits and stuff like us, then make a good wiring diagram before you beginning to re-wire her.
btw - the amount of and cost of replacement wire may surprise you. We're at over $250 and counting, just for wire. Which reminds me, I need toupdate our refurb thread.
Chris
Old 05-30-2010, 10:23 AM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
No worries, the wiring will survive a cleaning as long as power is off a couple of weeks for it to dry out. A thorough foot-by-foot inspection looking for rodent chews and abrasion damage before it gets wet is wise!
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
How To Remove These ??? Clyde-2 Doors & Locks 11 04-14-2010 07:32 AM
How to remove my letters erock53 Clearcoat, Exterior Paint & Trim 1 08-24-2009 02:43 PM
How do i remove a/c 65 caravel? kevinkatz Furnaces, Heaters, Fireplaces & Air Conditioning 8 07-30-2009 08:29 PM
Remove 2 tires? azflycaster Tires 14 03-24-2008 08:27 AM
?How to Remove Inner glass? Blu_Hwy_Lady Windows & Screens 7 12-17-2006 08:15 PM
