Old 08-18-2019, 03:36 PM   #1
1974 Argosy 22
kalmamazoo , Michigan
74' Argosy Wiring/Electrical
I've recently purchased a 22' Argosy 1974. The electric on the interior works, but the 7 blade connector does not. I pulled up the flooring at the front because there was some that needed to be replaced due to squirrel/water damage. The rest of the flooring looks good.
The wiring for the 7 blade connector has either been cut or chewed through just beyond the interior shell. There does not seem to be anywhere visible where that particular wiring runs. The colors from the 7 blade connector are the same as what is inside the shell. The wires stop and there is an addition 3 ft of trailer/aluminum belly that is exposed. I also can see a bit inside the flooring at where the table legs were, and cannot see any exposed wiring.
My questions: where does the 7 blade connector wiring run and connect to? Does anyone know where I can find a wiring diagram for this model?
I'm a total novice and need any help possible!
amart84 is offline   Reply With Quote
Old 08-18-2019, 07:40 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
The 7 blade connector has wires running to the running/tail lights, brakes, left brake/turn, right brake/turn, reverse lights, a fat wire to the house battery+, and a fat negative wire to the battery - or frame.
You should note that the wiring standard used in 1974 Airstreams is different from the current one, so you have to do a little umbilical customization to get things to work if your umbilical has not already been rewired.
My Airstream Umbilical Replacement blog post might be helpful.
TheGreatleys is offline   Reply With Quote
Old 08-18-2019, 10:06 PM   #3
kootenayken's Avatar
1976 Argosy 22
cranbrook , British Columbia
We had to rewire the trailer connector to match our F150 connector before we could move the trailer. The trailer wiring was Brown-right turn & brake, Red-left turn & brake, Green-tail & running light & licence plate, Yellow-brake controller, Black-brake controller, Blue-12 volt and White-ground.
kootenayken is offline   Reply With Quote
Old 08-18-2019, 11:27 PM   #4
1976 Argosy 22
In the last post Black-backup lights
Old 08-19-2019, 05:43 AM   #5
1974 Argosy 22
Inside Wiring
The wiring Im curious about is from the 7 blade connector, but I am curious about where it connects once it goes from the outside connector to the inner shell. Inside the trailer it goes about 7 then is broken.
ID:	349898   Click image for larger version
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 07:24 PM
general electrical/wiring in 62 bambi roadtrip07 Electrical - Systems, Generators, Batteries & Solar 4 07-07-2005 09:15 PM
wiring electrical connector frederic.c01 Electrical - Systems, Generators, Batteries & Solar 3 02-27-2004 12:59 PM
Electrical/Battery Wiring Texas'68 Electrical - Systems, Generators, Batteries & Solar 1 09-15-2003 03:30 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
