Old 06-26-2004, 01:24 PM   #1
73 Safari
1973 23' Safari
Ellijay , Georgia
Send a message via MSN to kadyacres
73 Safari - Need Electrical Pigtail Between Vehicles
Just purchased a 73 Safari, as is, (big project ahead) and desperately need the electrical cable that runs from a outlet in the body behind the LP tanks and goes to the tow vehicle.
Can anyone advise where these can be purchased? Thanks
kadyacres is offline   Reply With Quote
Old 06-26-2004, 01:39 PM   #2
RichardT's Avatar
Just go to your local trailer place or wal-mart and buy both ends you need in the trailer parts section, and make it yourself, you will linkely not be able to buy one pre made, unless you find a used one.
RichardT is offline   Reply With Quote
Old 07-05-2004, 08:39 AM   #3
kadyacres
We have the wire, plugs, sockets, brackets and boots for that set up.
You can make the cable up yourself, or we can do that for you.
Old 07-05-2004, 10:54 AM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Connections
You can also try this site for the 7 pole weather tight connection & cord to the truck: http://www.tjtrailers.com/store/trai...ness-kits.html.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-05-2004, 12:23 PM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
For the vehicle end, yes. The trailer end, however, is a different plug. One would have to convert the trailer side socket to a new style 7-way round also in order to use these parts, or order the correct plug from Andy or Airstream.
Uwe
www.area63productions.com
Old 07-05-2004, 01:10 PM   #6
LOST , Hawaii
TJTrailers is a good site to bookmark, they had parts I couldn't find anywhere else.
John
74Argosy24MH is offline   Reply With Quote
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Quality of new AS: 2004 22' SAFARI lee 2004 Safari 7 01-02-2005 07:13 AM
Need electrical help '61 Safari Rick Dotson Electrical - Systems, Generators, Batteries & Solar 4 04-23-2004 07:01 PM
Electrical problem--99 safari Andrew Carey Electrical - Systems, Generators, Batteries & Solar 2 11-16-2002 02:04 PM
Problem with electrical system (1965 safari) rslaymaker Electrical - Systems, Generators, Batteries & Solar 4 06-13-2002 05:49 PM
