Old 11-09-2005, 09:24 PM   #1
72 Tradewind: Overhead 3 way light switch
I'm replacing the 3 way switch that controls the 6 lights in one of the central overhead panels. Prior to 74, the switch was controlled by turning a whimpy little, black plastic shaft. The post-74 models had a steel shaft that accepted a knob over the top. I was sent the wrong switch. (later model 74 switch) I'm not very concerned about model year purity as much as I am durability. Does anyone have any advice on which switch would be better? The one with the black plastic shaft seems more prone to wear but if the one shipped is more durable, I'll make the change.
Thanks, John
yochanan is offline   Reply With Quote
Old 11-10-2005, 06:49 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
My 77 has the metal shaft switch. It is still working after 28 years. Not bad.
Old 11-10-2005, 08:09 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I just replaced one of the switches on my 75. I quess 30 years might be old enough. The one I have has the metal shaft and the big round knob that screws on to it. The replacement switch did come with the plactic small knob, but that unscrewed and exposed the shaft. The Airstream part for mine was 50063 and I got it at Oasis RV in Tucson. It was 12 dollars.
Richard
Old 11-10-2005, 09:52 PM   #4
Thanks for the comments. I'm going to return it for the correct switch for the 72. I took the switch with the metal shaft to the trailer this evening and it looks as if the body of the switch is too big for the mount that's riveted into the light housing. I could bend some things to make it fit but I'm just going to go with the original equipment.
Old 11-11-2005, 06:35 AM   #5
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 220
A Less Expensive Alternative
After searching high and low, I finally found these at Lowe's for about $3.75. I had to extend the mount about half an inch to account for the shorter shaft on the switch (drill out two rivets and put a spacer in between) and it works just fine. The brass knob may be removable (and replaced with larger orig knob) but I'm afraid of breaking it so I'll just leave it as is.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 11-11-2005, 06:49 AM   #6
Retired.
. , At Large
The metal switches (2 way only) are the originals, and still work like new after 43 years in our coach.
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 06:31 PM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
