Old 06-16-2015, 07:32 PM   #1
1972 31' Sovereign
rhinebeck , New York
'72 Sovereign Land Yacht porch light woes
So I got this 31-footer in near perfect condition except the front lounge lights and range hood exhaust fan didn't work - so I replaced the blown 10 amp fuse in the Univolt box and All came back to life! ... but no outside lights So I bought a new scare light assembly and porch light socket as I'd learned that one wont work without the other and soon they both Worked! My girlfriend comes home to a beautiful externally-lit patio and just touches the unattached porch light housing and *spark* there goes the fuse ... after the newly blown fuse is replaced and the housing is firmly attached, I plug in the power and *pop* goes fuse #2.
So after all this stupidity the stupid question is: Why won't the ground wire ground? or What's the best way to secure the ground wire to keep this fuse from popping and keep my outside lights on?
3irdeyephoto is offline   Reply With Quote
Old 06-16-2015, 09:13 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Let me see if I understand this. You replaced the porch light and the scare light. Both worked while the porch light socket was hanging free, but after installing the porch light socket into the housing, the fuse is blowing immediately. Is that correct?
You say the fuse blows as soon as you plug in power. Do you mean the shore power cord? Do you have a battery to provide 12 VDC power without being plugged in? Does the fuse blow before you turn on the light switch for the porch light?
Kinda sounds like you wired the socket backwards. As long as it was not connected to the trailer, it worked ok. But as soon as you installed it, the fuse blows. That's my guess.
Chris
Old 06-16-2015, 09:35 PM   #3
1972 31' Sovereign
Thanks, I'll try and explain in better detail ... I replaced the entire scare light assembly first and no light came on. That's when I learned it shares it's circuit with the porch light. I then wired the porch light with the same white/black wiring arrangement as it was before (white for ground/black for power) the only difference is I didn't solder the ground, I just wrapped it around the bracket and taped it. Both lights worked initially until the whole unit was moved and arced (sp?). I thought it might be due to the cover not being mounted since the bulb socket bracket mounts to the cover and the ground wire connects to the same bracket (confirmed by airstream). So I checked my connections, mounted everything firmly, changed the fuse and plugged in the power and the fuse popped the second I did (because I had left the light switch on?). This is on shoreline power only, no battery at all. Oh, and I didn't have any electrical tape so I used duct tape - could this be the culprit?
Old 06-16-2015, 10:41 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I think 3rdeye got it right, the socket is wired backward, regardless of the color of the wires.
Either that or hot wire on the new light is grounded agains the housing.
It is probably the first option.
New does not always mean right.
Old 06-17-2015, 10:34 AM   #5
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
My '72 Ambassador's porch light is wired backwards, as well! The ground leg is switched... how silly is that?
SuzyHomemakr is offline   Reply With Quote
Old 06-17-2015, 10:42 AM   #6
1972 31' Sovereign
Wow, Suzy! Can you give me more detail? And I don't know, J.Morgan, I took apart the scare light this morning and it only has one wire - it's the power line and it's the black one. Since these two run on the same circuit I'm assuming the black wire in the porch light is also the power. As I mentioned, the white wire was soldered to the old rusty fixture in the porch light so I'm thinking it was the ground because it wasn't connected directly to the bulb socket itself.
I'm gonna try again this time using real electrical tape to insulate the ground wire (and a fresh 5-pack of 10 amp fuses) and will post results ... anybody else have any ideas?
Old 06-17-2015, 11:24 AM   #7
1972 31' Sovereign
Ok, the electrical tape seems to have worked, as well as the wiring order (white ground/black power) Both lights are working again!! But ... now if I try to mount the bracket to the light cover it arcs - is this a materials issue? As in, should I be trying a nylon or other non-conductive screw? Or should I just close it up and leave well enough alone ?
Old 06-17-2015, 03:35 PM   #8
1996 25' Excella
Tillsonburg , Ontario
Take the fixture off the wires and check for 12 volts on both black and white wires. It almost sounds like the white wire has 12V positive on it and when you assemble the fixture into the trailer it gets grounded (shorts)
If there is only one wire on the fixture then the ground is meant to be back through the trailer body and you shouldn't need a neutral wire.
JCW
JCWDCW is offline   Reply With Quote
Old 06-18-2015, 08:03 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If there is only one wire to the fixture, and you blow a fuse every time the fixture touches the trailer, then it is about sure that the fixture is shorted out.
sovereign
'Porch' Light Replacement Fixture with 1141 Bulb AirConditioner Electrical - Systems, Generators, Batteries & Solar 4 09-10-2015 11:56 PM
Porch light cleaning GlenCoombe Lights - Interior & Exterior 10 06-30-2013 02:16 PM
1974 Sovereign exterior light woes texasbound Lights - Interior & Exterior 11 09-14-2012 02:32 PM
1974 Sovereign Land Yacht :: 1974 Airstream Sovereign Land Yacht MyTwinkie Airstream Registry Discussions 0 01-13-2012 08:51 AM
The $8 Porch Light Silverfly 1960 - 1964 Overlander 2 09-21-2004 06:25 PM
