Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 09-27-2007, 03:31 PM   #1
nm_mike
Profile:  1972 Argosy 22
madrid , New Mexico
'72 Argosy 22 - 12v wiring diagram
Hi all,
I just towed a 1972 22ft Argosy trailer from Detroit to New Mexico and will be living in it. When I got here I found that I have lost some of the 12v systems (they worked previously). The overhead lights, bathroom light and the swivel spots at the front work but the water pump stove fan and lights over the sink and the left side seat don't.
I have searched the threads and have learned that the 12v system seems to run overhead at centerline and then down the sides to where needed. Did I get this right ?
I was thinking of just running a 2-conductor cable to the water pump anyways. I also will be adding some solar panels.
Anybody have any ideas on where the problem could be ?
Thanks for your help,
Mike
Life is not a journey to the grave with the intention of
arriving safely in a pretty and well-preserved body,
but rather to skid in broadside, thoroughly used up,
totally worn out and loudly proclaiming, FRAK ME!! What a
ride!!!
nm_mike is offline   Reply With Quote
Old 09-27-2007, 03:39 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
Welcome to the forums. You will probably find that at least one fuse in the fuse panel has either jostled loose from road vibration, or lost connection due to corrosion.
You will find the fuse panel inside the Univolt (heavy blue box that says Triad on it), probably in the streetside (driver's side) cabinet in the bathroom. On the floor. Behind everything. Plug the trailer in, and follow the HUMMMMM.
Change is inevitable, except from a vending machine
AIR#2611
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 10:17 AM
1975 Argosy Need wiring diagram to repair directional lights, etc. Rt66Argosy Member Introductions 2 09-27-2006 09:51 AM
Anyone have a Wiring Diagram? Chopper Electrical - Systems, Generators, Batteries & Solar 14 09-22-2006 09:49 AM
Wiring diagram raebaker06 Electrical - Systems, Generators, Batteries & Solar 0 08-29-2004 11:02 AM
wiring diagram frederic.c01 Electrical - Systems, Generators, Batteries & Solar 1 05-30-2004 01:59 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
