Old 07-21-2012, 12:59 PM   #1
1972 27' Overlander
stony brook , New York
'72 Airstream Overlander Land Yacht
replacing univolt system with a power max boondocker, have many questions, NEED HELP!!! anyone with knowledge on installation and wiring would be helpful and appreciated!!!
tbonejon is offline   Reply With Quote
Old 07-21-2012, 03:30 PM   #2
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
did you manage to get the old unit out? any progress?
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 07-22-2012, 03:26 PM   #3
1972 27' Overlander
yes and i wired up new converter and fuse block but i have no 12 volt power at all, so something is amiss, trouble shooting so far no luck
Old 07-24-2012, 09:57 AM   #4
Powerlineman's Avatar
1974 31' Excella 500
Wellston , Jackson
Have you had any luck Mr. I'm getting ready to go threw the same thing. And also. What converter did you go threw.
Powerlineman is offline   Reply With Quote
Old 07-24-2012, 10:46 AM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post pics and give us a description of what you have done? I will assume you have the 120 volt power to the converter. Are you sure the polarity is correct from the output of the converter? Do you have 12 volts at the converter and not to the trailer?
Old 07-24-2012, 11:55 AM   #6
Mexray's Avatar
1978 28' Ambassador
Morada , California
It should be a rather simple matter to find your problem...
As TG mentioned...and, if the anser is NO to any of these steps, back up one step to resolve your problem...
1. do you have AC power to the new converter/charger?
2. with a digital volt-ohm meter, do you have POS & NEG 12 volt DC at the OUTPUT side of the converter - is the polarity correct?
3. do you have 12 volt DC at the input to the fuse panel?
4.have you checked the large amp fuses (or circuit breakers) that are in the fuse panel circuit to the battery cables?
5. check all fuses in the fuse panel for proper installation, blown fuses, etc...
In other words, start at the SOURCE and work your way through the wiring till you find where it isn't connected...
Ray & Pat; Morada, CA
Old 07-31-2012, 04:20 PM   #7
1972 27' Overlander
up and running, .was fairly simple even if your electrically challenged like myself. But it helps to have a friend who's a master electrician. Dinner and drinks did the trick. If anyone needs more info or help/ pictures contact me threw this site directly and i will try to be of assistance.
