Old 11-02-2011, 08:39 PM   #1
1971 31' Excella 500
Altoona , Pennsylvania
'71 Excella 500 converter replacement
Hi,me and my wife recently purchased a 71 Excella 500.Everything works,even the 8 track player.My kids didn't even know what one was.The converter is on the left side going towards the rear of the trailer.It's under the middle bunk.We'd like to add a flat screen in the living area and a dvd player.I would also like to upgrade the sound system to a cd player,add an amp,a few subs,and replace the factory speakers.Any suggestions on what kind of converter to change to? I'd rather get bigger than what I need because I'm not sure how much the sound system will draw.This is our first camper so it's all new to me.Thanks!
dan442 is offline   Reply With Quote
Old 11-02-2011, 09:30 PM   #2
1969 27' Overlander
Albuquerque , New Mexico
Dan, I can't speak specifically about the Excella, but generally speaking, you don't want to draw more than what the original system was designed for. If the Univolt converter is a 30 amp, then you want to make sure that the new converter doesn't provide more than that on the existing fuses and wiring. That's for the DC voltage portion.
Most of the items you mention are going to be powered off 120 vac, so you want to make sure you don't exceed the maximum rating of the main circuit breaker. Again, probably a 30 amp breaker.
There are ways to split up the loads through a 4-6 breaker panel for the 120 vac, and you can also add circuits to the DC portion and change-out the old fuse panel, but it gets kind of technical.
I think most people replace the old Univolt with a new electronic converter/battery charger because they're more reliable and are better for the batteries. I switched to an Intellipower, and it seems to work fine.
Keep in mind, the plug connector for shore power is probably only rated for 30 amps, or maybe 50 amps, vac.
If you search through the forums, there's quite a bit of discussion on the subject.
edglenn is offline   Reply With Quote
Converter for 1988 Excella crios Batteries, Univolts, Converters & Inverters 7 10-14-2011 07:32 PM
The Peapod :: 1976 Airstream Excella 500 peapod76 Airstream Registry Discussions 0 08-19-2011 08:31 AM
1976 Excella 500 31' What a dream! behrstreamin Member Introductions 3 05-28-2011 06:58 PM
