Old 03-26-2015, 09:03 AM   #1
1969 21' Globetrotter
Calgary , Alberta
70' Globetrotter short
So we just aquired a 1970 globetrotter. I was hooking up a new battery will being plugged into the house on 120 and the positive terminal hit metal and shorted out everything. I have most things working now except for the front interior lights and the radio. Is there a set of fuses I don't know about inside the trailer?? Please help. Wife thinks we got a dud. Also could use some advice as to what the switches on the wall above sink are and near the door. Thank you
CDNCampers is offline   Reply With Quote
Old 03-26-2015, 09:40 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums, and to vintage trailer ownership.
So just a few words in advance--if this trailer is in its "original" condition, that is to say, that nobody has spent thousands of dollars to reverse the 45 years that have passed since it was built, then hold onto your hat, because you will find that the only thing on these trailers that seems to last forever is the shiny aluminum shell. Manage your expectations--and expect to do some work making this trailer safe and functional.
Now to the electrical: Did everything work before you had the positive terminal incident with the battery? I would guess that it did not. If you think about circuits, you have your positive and negative terminals on the battery both hooked up, and then the positive termal comes in contact with the shell. The "short circuit" you just created is going to go from the positive terminal, through the very short section of shell, and then into your grounded negative terminal. All of those DC components in the trailer should be out of the "short" circuit as the electricity is going to take the shortest path of least resistance.
You should have a very simple fuse panel in the vicinity of the battery and converter, and that is it for panels unless a previous owner retrofitted something. There might be an in-line fuse in the wiring immediately behind your stereo (but I don't recall one on my '73), but there are no inline fuses in your lights.
The switches next to the door probably operate the porch light, if equipped. Switches above the sink likely to be for the galley roof locker (cabinet), and the light over the sink. Again, this will depend upone any mods the previous owner may have made.
good luck!
Old 03-26-2015, 10:10 AM   #3
Calgary , Alberta
Thank you. The radio did work previous to the short and the inline fuse behind it seems intact. As far as mods to the electrical all i can say they have changed is the 120 outlets. The same power converter sits in the back next to battery with three glass fuses and the 120 in the closet. They did have the radio on a switch that was designed to go from 12 to 120 I presume Any advice would be awesome and appreciated. I am in over my head!!
Old 03-26-2015, 10:57 AM   #4
Calgary , Alberta
Also any tips on seeing if my water pump works or not would be appreciated. On Our old trailer we only had a manual system. This whole pump and pressure and all that is new to me.
Old 03-29-2015, 08:04 PM   #5
Calgary , Alberta
Everything working now. Will have pic to posts in one after new cabinets and counters in.
Old 04-09-2015, 10:54 AM   #6
Calgary , Alberta
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 05:34 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 02:41 PM
help dead short pk63 Batteries, Univolts, Converters & Inverters 6 05-29-2002 09:56 AM
