Old 04-10-2005, 10:55 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
7 Way Socket
Well, we just had to drive back from the NorCal Rally w/o trailer brakes
The morning we left to go the rally, I did not have brakes, so I cleaned the corrioded pin on the 7 way socket on the truck. And that got it going for the trip there.
The morning we left the rally no brakes again and I could not get it cleaned up enough to get it going. But since we have an oversized tow rig and light trailer we managed home slowly and safely.
The reason my socket went bad is because when it rains it gets wet. I tried sealing up where the wires run in the back of the socket but the pins still get wet. I just have the cheapy aftermarket camping world socket.
Is there a better weather proof model out there available?
-Tim
theVAP - Airstream Podcast
Old 04-11-2005, 12:03 AM   #2
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
You might want to put a little grease on the pins and socket....yes, it has to be cleaned up from time to time, but the grease provides good electircal conductivity and coats the pins and sockets connectors against water.
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Old 04-11-2005, 04:18 AM   #3
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
tim
you might try a stock one from GM.
lps 2 sprayed in the socket one in a while will keep it free of corrosion.
john
you call them ferrets, i call them weasels.
Old 04-11-2005, 07:27 AM   #4
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
7 way socket
Tim, I had an old Buick and every time we got a hard rain it wouldn't start, I finally found some spray at the auto parts store and sprayed it in the dist. cap and no more problem, I had to repeat this every couple months, I forget the name of it but if you check around I am sure you can still get it. Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 04-11-2005, 08:01 AM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The stuff is called Wire Drier, but I think maybe white lithium grease might be better, although it would tend to promote dirt acumulation.
Old 04-11-2005, 10:51 AM   #6
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
OK, I guess my mistake was not putting on dielectric greese. I was hoping they made a more quality socket with gaskets or something.
Guess I'll be purchasing a new socket and a tube of dielectric greese.
Thanks for all the info!
-Tim
Old 04-11-2005, 12:12 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
tim
i sure the quality of these sockets varies wildly, still you may want to check with your chevy dealer and see what they have.
they are plug and play, it goes right in between the connector for the trucks tailights. standard gm weather pack connectors are water tight! and, i know the back of the standard issue gm socket has a gasket in it.
john
Old 04-11-2005, 12:16 PM   #8
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks John.
My truck did not come with a trailer package. The PO put on a 6 way socket, so if there was a factory plug on there he cut it off.
When I wired the 7 way I had to put on the individual wires. So the OEM socket probably won't work for me.
-Tim
Old 04-11-2005, 12:47 PM   #9
Elgin , Texas
Images: 164
Hey Tim,
Underneath the back of your truck, almost to where the bumper is, should be a "junction module" (calling it that because I don't know its real name). I'm pretty sure that it's a standard type of thing, with or without the trailering package. All of the lights on the back of the truck - tail, turn, brake, backup and license should be plugged into it. Then there will be one main connection from it leading to the front fuse panels and other connections. There should be an available socket on the junction module specifically for plugging in the GM trailer harness. The six-way was probably wired as you described since there wouldn't have been any way to plug it directly into the junction without a GM plug on the end of it.
Anyway, I'm pretty sure it's up there - might have to remove your spare to see it, though. If possible, and for the most reliable connection, I'd have to go that route.
Good luck getting it all sorted out!
bake315 is offline   Reply With Quote
Old 04-11-2005, 12:56 PM   #10
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks Dave,
That's very interesting. I will check that out!
-Tim
Old 04-11-2005, 01:41 PM   #11
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
The local dealer wants $50 for the GM socket. But he warns that it only mounts on the factory hitch which I don't have.
A little more hunting I found this OEM replacement that plugs into the factory harness. It's $20.
If my harness plug has been cut, like I think it may have by the PO then I could get this kit which includes a new oem plug and socket. This costs $35.
Both of these claim a weathertight seal.
They also have this little boot that goes over the trailer end when unplugged.
At lastly they have the dielectric grease too.
Next step is to see if my oem plug is intact under my truck when I go home tonight.
Thanks for all the input.
-Tim
Old 04-13-2005, 12:20 PM   #12
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Angry Major Bummer
My OEM trailer socket is gone. The last owner must have cut it off and wired their plug direct.
I found a nice GM style 7 way plug for $25 made by Hoppy that would have connected right to the oem socket....
I checked with the dealer and they do not sell the trailer vehicle side plug seperately. I checked the local auto wreckers and those plugs are all gone, even off the late model Fords
Looks like I'll be having to wire it direct. At least this new one is completely sealed and also has a gasket around the front flap door. As a bonus it also has the 4 way for a utility trailer.
-Tim
Old 04-13-2005, 12:45 PM   #13
Elgin , Texas
Images: 164
Bummer!
Man, that IS a major drag. Well, by wiring it in yourself you can at least take away the satisfaction of knowing your connections are good and solid.
Old 04-13-2005, 07:00 PM   #14
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
One word of caution, mine was put on by a reputable trailer supply that has been in business for as long as I can remember. When installing the brake controler they used "butt connectors" crimped on the wire. Sometimes I had brakes sometimes I didn't. I was certain that my problem was in the external 7 pin connector. Finally I had a failure and couldn't get it working. I found the problem under the dash not in the connector, FWIW. Not saying this is your problem but you might want to check it with your meter first if you haven't already done so.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Cordless Drill Motors jaco Off Topic Forum 32 07-22-2009 09:40 PM
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
Thin Wall Socket? ALANSD Mechanics Corner - Engines, Transmission & More... 13 11-29-2004 08:37 AM
Brake light socket needs to be replaced Argoman All Argosy Trailers 5 09-16-2004 12:49 PM
