Old 04-13-2005, 07:35 PM   #15
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Wd-40
Try a little WD-40...it stands for Water Displacement for a reason. On my farmall, whenever I had moisture in the rotor, it would not start. I'd spray alot of WD-40 in there, and put it back together, and it would run like new.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 04-13-2005, 07:41 PM   #16
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Rob I did that in mine and thought the wd smelled funny. I had used clear lacquer.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 04-14-2005, 05:33 AM   #17
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
Originally Posted by Tarheel
When installing the brake controler they used "butt connectors" crimped on the wire....
I just rewired my trailer connector and using butt connectors. I filled them with dielectric grease before crimping and then covered the joint with shrink tubing. Finally the whole thing was covered with a cable sleeve and wrapped with vinyl electrical tape. I think that the joints should be trouble free for a long time.
Best of luck,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 04-14-2005, 08:16 AM   #18
Tarheel's Avatar
Images: 21
Steve they should work fine for a very long time. The touble with the butt connection, only one of them, was that the mechanic pushed the wire too far in and crimped on the insulation instead of the bare wire. Sometimes, in fact most of the time, there was a connection, but every once in a while the wire would move and the connection would be lost and so would the brakes. It was a really hard one to find. A quick electrical meter test when the brakes aren't working picked it up for me.
WBCCI # 348
Old 04-18-2005, 06:26 AM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Angry
Rob
Just wait until it dries, I got impatient, and put the cap back on while it was still wet with WD40. A little-known fact is WD40 will explode in a confined place if it is exposed to a spark, like you would find in an ignition system. Maybe that is why we can use it to start diesel engines. I had to walk to an auto parts store and buy a new cap and rotor...
Old 04-18-2005, 08:05 AM   #20
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, I've used it many times to test for spark/fuel when troubleshooting small engines that won't start. a ready-substitute for starting fluid. 1 squirt down the carb throat, and a few quick pulls of the starter will reveal whether you've got spark or not. if you do, it'll run for a couple of seconds...which would mean then, that you've got a fuel problem.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Cordless Drill Motors jaco Off Topic Forum 32 07-22-2009 09:40 PM
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
Thin Wall Socket? ALANSD Mechanics Corner - Engines, Transmission & More... 13 11-29-2004 08:37 AM
Brake light socket needs to be replaced Argoman All Argosy Trailers 5 09-16-2004 12:49 PM
