Old 08-08-2005, 01:46 PM   #1
7-way round pin?
As I get ready to pick up my 1963 Globetrotter, I'm trying to get ready. Problem is finding a 7-way round pin connector. Nobody seems to sell these. I tried online, and ordered one, and they sent me a 7-way flat. Finally in some dusty clearance bin I found a seven pin connector (male) that I bought for six bucks. Problem is I don't know for certain that it is what I want. It's about 1.5 inches in diameter and the top pin is longer and fatter than the others. There is a half inch long, 1/16 deep groove at the top (presumably to force the correct orientation) as well as two ridges at the top, flanking the groove, and three at the bottom (also for orientation, or for snugness?)
Is this the correct receptacle? If not where on earth does one find these?
Geof
Almost forgot: It says SAE J560 in it and is made by Phillips.
abruzzi is offline   Reply With Quote
Old 08-08-2005, 02:14 PM   #2
Westfalia's Avatar
2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Try the Hitch corner:
http://www.hitchcorner.com/trailer_plugs.htm#plugs
They are a Denver area shop, but sell their wares online as well. Fast and friendly. They should have exactly what you need!
Chris and Christina- Boerne, TX / Evergreen, CO - TAC TX-7
2008 27'FB Int'l Signature CCD
Westfalia is offline   Reply With Quote
Old 08-08-2005, 02:17 PM   #3
RichardT's Avatar
Just get a modern 7 way flat to put on your tow vehicle and replace the one on the trailer too, that way you will be able to hook up and go with any truck or use the truck with other trailers..
It is very easy to rewire and you will only need a screwdriver, some wire cutters, and the part. If you need a wiring diagram just ask or look it up in search.
RichardT is offline   Reply With Quote
Old 08-08-2005, 02:25 PM   #4
abruzzi
The round pin connectors are superior to the flar pin connects, in that the terminals are self cleaning.
Not true with the flat pin. In fact one grain of sand can stop a flat pin connection from working.
Most any Airstream dealer should help you, if not we carry them in stock.
Old 08-08-2005, 02:33 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Geof
Geof,
I have seen the round pin plugs at truck stops.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 08-08-2005, 02:40 PM   #6
I presume then that what I found is incorrect?
Geof
Old 08-08-2005, 03:12 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
...Problem is I don't know for certain that it is what I want. It's about 1.5 inches in diameter and the top pin is longer and fatter than the others. There is a half inch long, 1/16 deep groove at the top (presumably to force the correct orientation) as well as two ridges at the top, flanking the groove, and three at the bottom (also for orientation, or for snugness?)
...I presume then that what I found is incorrect?
Sounds like you have the right one. FWIW, below is the original Signal Stat connector that came on my Overlander.
The ID reduction in some of the pin holes are hatched mud dauber nests.
Tom
Old 08-08-2005, 03:23 PM   #8
TomW's Avatar
1967 26' Overlander
And for good measure
A wiring guide:
Tom
Old 08-08-2005, 03:25 PM   #9
1975 29' Ambassador
Reno , Nevada
I find the round pin connectors at truck supply stores. They are a standard connector on commercial tractor trailer rigs.
Old 08-08-2005, 03:38 PM   #10
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You did not fill in your profile with the type of vechile you are towing with. I use a Chevy truck now and have converted my two trailers over to the round flat pin connector that is standard with the newer trucks. Be aware there are two different wiring harnesses for the GM's and they sold me the wrong one and I had to modify it on the road to get the brakes to work right when the running lights are on. No biggy but a pain.
Old 08-08-2005, 04:12 PM   #11
Here's a pic
Thanks for all the help... Here is a pic I took of the receptacle. Also based on the attached diagram, it looks like the white is the fat pin, is that correct?
Old 08-08-2005, 04:19 PM   #12
TomW's Avatar
1967 26' Overlander
Doh! I just KNEW you were going to ask that, and while I think that is right (the diagram sure infers it), I can't say for sure.
Hopefully, someone will chime in, but if they do not, DavidZ71 has the round pin connectors, and might be able to help. Drop him a PM if this thread does not get a good followup.
Tom
Old 01-10-2008, 12:04 PM   #13
todcor's Avatar
1967 26' Overlander
Derby , Kansas
Tom
This might help.
http://www.airforums.com/forums/atta...1&d=1199991737
todcor is offline   Reply With Quote
Old 02-03-2010, 06:27 PM   #14
tucson , Arizona
thank god
i live in tucson az and i have been through the same experience as you, it sucks. theres a place called wheel equipment that sells the adapter your looking for. its made by velvac and is part number 591010. its a bit pricey but its well made. wwwvelvac.com
454silverado is offline   Reply With Quote
1978 24ft Argosy brakes juel Brakes & Brake Controllers 6 10-31-2004 04:14 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 10:26 AM
Quarter Round Molding melprice Floor Finishes 7 09-11-2002 10:59 AM
