Old 10-29-2014, 08:56 AM   #1
Lothlorian's Avatar
Loganville , Georgia
7 way connector question 73 Overlander
I made a decision to have my pole connector replaced with the newer type connector. The old was not working well and I had to fool with it to get things to turn on.
I got the Airstream back and everything worked great. I noticed that when I went to put the cover over the wired connector on the inside of the trailer I noticed a cut wire. It was a red wire attached to what looked like was a reset which was connected to a blue wire. What did they Cut?
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 10-29-2014, 11:04 AM   #2
Lothlorian's Avatar
I am bringing this question forward again so airstreamers can read it and comment if they know the answer.
Brian & Adrienne
Old 10-29-2014, 11:13 AM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Blue would have been the charge circuit to the AS battery from the vehicle.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-29-2014, 12:10 PM   #4
Lothlorian's Avatar
I read that and looked at the diagram, but what I found confusing is why it was hooked to a reset breaker on one end and a red wire at the other end.
Brian & Adrienne
Old 10-29-2014, 01:30 PM   #5
millertimeUS's Avatar
1976 25' Tradewind
Perhaps they altered your breakaway wiring, the blue power wire gets attached to the breakaway switch which then is connected to your brakes when it returns to the trailer from the switch.
76 'Airstream Tradewind
Matt
millertimeUS is offline   Reply With Quote
E-Z Connector: Upgraded 7-Way slowmover Brakes & Brake Controllers 17 11-02-2011 02:33 PM
'71 Tow vehicle/trailer 7 way connector wiring Lumatic Lights - Interior & Exterior 12 08-15-2010 08:19 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
2nd Battery/7-way connector wbrownrr Electrical - Systems, Generators, Batteries & Solar 8 05-19-2005 05:22 PM
