Old 04-27-2015, 02:07 PM   #1
Tulsa , Oklahoma
7 pole connector
I am new to the forum and just purchased a 2006 Bambi using a Mercedes 350 SL 4 matic as TV. I connected the 7 pole connector and did not have brake or turning signals. Then I discovered that the batteries were dead. I have recharged the batteries but want to know if there is a way to troubleshoot the connectors?
Eyeary is offline   Reply With Quote
Old 04-27-2015, 02:40 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
The first thing I would try is spraying the plug full of contact cleaner and moving the plug in and out a number of times to clean things out. That might be all it takes.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 04-27-2015, 03:27 PM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
You may find that your turn signals and brake lights do not work properly because the load from the LED tail lights on the AS are not strong enough for the Mercedes to recognize. "It's a German thing." There is an adapter that you can get from eTrailer that connects to the pigtail that will alleviate that issue if that is the cause.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 04-28-2015, 05:24 AM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
The batteries in the trailer will have nothing to do with the running lights/brake lights/turn signals and brakes (other than the breakaway switch). Those are all powered by the tow vehicle.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 04-28-2015, 06:15 AM   #5
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I know nothing about the set up on the Mercedes, that said, Fords used to come with a wiring harness, that if one wanted to tow, one had to get under the dash and connect the harness to the harness which ran from the dash to the back of the Ford vehicle. This was true with the older Explorers at least. The easy way to test your TV circuits is with a 12v test light, ground to a metal surface, stick the prong into the 7 way plug and see if it lights up. If it does test it on all circuits with someone sitting in the drivers seat working the brakes and turn signals as you instruct. If all works then it's either the connection or something in the trailrer.
Good luck
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-29-2015, 10:00 AM   #6
Tulsa , Oklahoma
Thanks for input. You are correct, a full charge on batteries made no difference. Ordered adapter from etrailer
flag pole mounting and flag pole in general chrischarles General Repair Forum 42 08-09-2017 02:05 PM
rope and pole awning pole replacement link please greenrig Awnings 10 05-06-2009 12:52 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
Flag pole bracket/holder? Kistler Our Community 7 11-25-2003 10:29 AM
Pole Awnings Stefrobrts Awnings 12 09-02-2003 08:54 PM
