07-10-2012, 11:29 PM
1970 25' Caravanner
Incline Village
, Nevada
7 Pin Round to 7 Blade Trailer Connector Adapter Needed
I am new to the forum and new to Airstream. Just bought a 1970 Caravanner. Is there a thread or can someone give me advice on where I can buy the cable and connectors for the trailer lights? The Airstream has a 7 pin round and my towing vehicle has a 7 blade. Thanks.
07-11-2012, 12:37 AM
1988 32' Excella
Bonita
You'll need to get an adaptor from your tow rig to your trailer. I would try an RV store, they may have to order one.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
07-11-2012, 01:06 AM
1978 31' Sovereign
Oakley
Yry etrailer online...they have nearly everything, and they are super knowledgeable.
07-11-2012, 05:05 AM
Corona
The flat blade connectors often fail, as one grain of sand will stop a proper connection.
The round terminal connectors don't have that problem, since the terminals are self cleaning.
07-11-2012, 06:22 AM
1974 Argosy 26
Morrill
, Nebraska
Disconnect the house battery common/ground terminal before removing the trailer end plug. Especially if it is made of metal.
07-11-2012, 06:52 AM
1977 31' Sovereign
1989 34' Excella
McHenry
I have used my GM flat blade connector for 10 years without a problem. The flat blades are also self cleaning as you push the plug into the connector. Sand is easily dislodged. By not changing to the round pin, your tow vehicle will remain compatible to many other trailers that follow the industry standard.
07-11-2012, 11:28 AM
1974 Argosy 26
Morrill
, Nebraska
I haven't had any troubles with the flat blade connectors and I have them on several units. Even to connect the solar panel to my trailer.
09-06-2012, 04:51 PM
Tampa
7 pin round to flat HELP
Hello good folks
Same issue as Jeremy ... if I purchase a 7pin flat to 7 pin round does the wiring set up transfer to the TVs wiring output setup as per the attached photo ... hope that makes sense ... essentially what I see on the forums for wiring on round plugs (female round Trailer) do not match what I see on my TV outlet (male rectangle TV)
Please advise if you know
Best
Rob
09-06-2012, 06:06 PM
2000 19' Bambi
mt. Prospect
I changed the plastic flat blade connectors for metal round pin connectors - socket and plug. The connection pattern is different, though. I think the quality and connectivity are better, although it means that hooking up to a different trailer would be a problem.
09-06-2012, 10:45 PM
Tampa
Thanks Robert
There are 7 pin to 7 pin, roun to flat out there, just don't know if they change the circuitry appropriately ... photo = TV setup, diagram = round pin trailer set up
Any one know if it is the case??? ... please
Best to a GREAT forum
Rob
09-06-2012, 10:51 PM
Tampa
Round pin square pin
See attached rectangular pin formation with cover denoting configuration and round pin receiver for trailer with diagram explaining wiring set up
... hopefully additional helpful information for those who might be able to help
Best
Rob
09-07-2012, 12:15 AM
1970 25' Caravanner
Incline Village
, Nevada
Hi rob. I bought a cord from out-of-doors mart that had 7 pin round on one end and 7 blade flat on the other and it worked great! All lights and signals operated fine. Difficult to find and not cheap, you won't find them on amazon or oreillys unless you plan to use your 4 pin connector, I saw a lot of 7 round to 4 pin cords. Good luck
| Thread Tools |
| Display Modes |
