Old 08-03-2015, 06:58 PM   #1
2015 27' FB International
Prairie du Chien , Wisconsin
7 pin cord damage
I forgot to route the 7 pin cord over the weight distribution bar, and as I traveled down the highway, the cord drug on the ground, and needless to say, it was damaged. The cord was abraded, and several wires were abraded but still intact, although copper was showing. I taped it up so I could finish the trip and luckily everything worked, but now I need to make the permanent fix. How hard is this? Should I replace the whole cord or simply cut and resplice the cord using tape and shrink wrap? How hard is it to replace the cord on this new model International? My RV dealer is 4 hours away. If I replace, what connectors would you recommend?
KJJorgen is offline   Reply With Quote
Old 08-03-2015, 07:45 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
I would repair but that's me I don't like to buy things I can fix.
Not a very difficult task the wires are color coded so hard to mix up.
I would use a soldering iron and shrink tubing on each wire then tape the bundle real good for a permanent fix.
If you decide to repair you might consider shortening the cable so it would not drag on the road again.
Garry
Old 08-03-2015, 08:11 PM   #3
Ohiobrits's Avatar
Howard , Ohio
You can repair as Garry indicates. Replacement is a bit of a pain but can be done if you have time (2-4 hrs depending on how familiar you are with wiring type DIY). For the time involved to repair v replace I'd do the replacement. Cost you about $35.
I replaced mine since I fitted a ProPride which needs the extension and I was starting to get intermittent loss of lights/brakes and it was not clear which of the 3 connectors was the issue.
To replace the whole lead (FB):-
Inside the AS, take out the mattress
Unscrew the bed support panel closest to the front window (about 10 screws).
You will now be able to see down into the front storage compartment, remove the 3 screws that secure the white vertical panel that covers the 7 pin JB and inverter.
This will give you clear access to the 7pin wire connector junction box.
You can probably can get to the JB from the front storage hatch also if you would prefer but you will almost need to crawl in there to see what you are doing.
Open up the 7 pin wire JB (black box towards the front). Your manual will have the pin out diagram for the 7 pin connector with wore colors and locations. Make a note where each color wire goes in the JB and also where it is terminated in the 7 pin adaptor.
I bought this replacement one off Amazon - may be bit long for you but you can coil up any spare in the storage compartment. Note that the location of the cores by color do not match the one on your AS but there is a sketch with the new cable that will show you what color goes to what pin on the plug so you can match to your AS.
To remove the old cable you will need to CAREFULLY dig out some of the black sealant that seals the hole in the floor of the storage compartment where the cable goes out to the front of the A frame.
You can then start to pull the old cable back.
Make sure you securely tape a pulling wire to the end of the old cable as you pull it back towards the A frame. You will use this to pull the new one back through the A frame and into the storage compartment since the cable is run inside the A frame box section. As you pull back the old wire you will need to drill out a few riveted cable clips to enable withdrawal. I used some cable ties to secure the new cable after refitting in the same general locations.
Pull the old cable back, as soon as you see your pulling wire coming out of the grommet in the A frame, separate it from the old cable, attach your new cable securely with electricians tape and pull back.
Terminate the cable in the JB - check and double check connections.I confirmed end to end correct connection by measuring resistance from the plug pin to terminal in the JB. A few Ohms and you are connected, open circuit and you have something miss wired.
Connect to your TV and check all lights, brakes etc work as intended.
Confirm the free length of cable you want for your TV at the plug end, pull through any excess into the storage compartment and coil up.
Reseal hole in floor with sealant. You can buy the correct Airstream black sealant off their website or get something similar from your automative or home center.
Replace panels.
If you have done some wiring previously around the house or in a prior TT or TV you should have no problems doing this yourself.
Good luck.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 08-03-2015, 10:44 PM   #4
Mission , Texas
So from this description I gather that a jack on the trailer is not normal?
My 75 Overlander has a 7 pin jack on the outer wall behind the gas tanks, access behind the goucho.
nrgtrakr is offline   Reply With Quote
Old 08-04-2015, 01:43 PM   #5
Wise Elder
Jammer's Avatar
2010 30' Classic
When my 7 pin cable became damaged I replaced it with a jack (outlet, receptacle, frame mounted connector, whatever) so that I could carry a spare cable.
I also have installed a spring to hold the cable up and out of harm's way.
Old 08-04-2015, 01:45 PM   #6
Minipad's Avatar
2013 23' FB International
2013 25' Flying Cloud
In the Rockies, 6700' , Colorado
The first thing I do whenever I buy a new trailer is remove the plug on the end of the umbilical cord and wire into a nose box. A nose box is what you see on the front of most semi-trailers. On the new Airstreams, the forward side of the battery box, under the propane tanks is a good place to mount the nose box. I then create a pigtail (some people call them a whip) that plugs into the nose box and the other end into my tow vehicle. You could cut your umbilical on the trailer side of the damage and wire into a nose box. Then you will need to build a pigtail to connect to your tow vehicle. The advantages are numerous. For one, when in storage, I remove the pigtail and don't have weather issues with it. Second, by carrying a second, spare pigtail, I don't have to worry about rewiring the umbilical cord in the event of damage or just wear and tear.
Minipad is offline   Reply With Quote
Old 08-04-2015, 08:38 PM   #7
2007 25' Classic
Hutto , Texas
Small reminder when working on the umbilical cord. The battery charge line in the cable is connected to the trailer battery and can be live 12v at decent current levels unless you unhook the trailer end of the cord first.
Pull the ground cable(s) off the trailer battery(s) first is a good idea.
Wanderer2604 is offline   Reply With Quote
Old 08-05-2015, 05:06 AM   #8
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
.....don't feel alone, mine got ground down on the way home from the dealer.
A zip-tie around the 7-pin, (an O-ring on the boat trailer), and a D-ring in the tongue latch has solved the problem.
Problems with cover for 7-pin cord RAH Hitches, Couplers & Balls 2 05-25-2015 06:42 AM
Nos 7 pin trailer cord connector bmklawt Electrical - Systems, Generators, Batteries & Solar 0 11-14-2010 10:34 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
'72 trailer 7 pin vs '99 truck 7 pin wiring? Hawkeye5 Lights - Interior & Exterior 4 08-02-2008 01:34 PM
