Old 12-21-2015, 07:04 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
6v batteries /2+2=x
If I run 2 6v batteries each rated at 200ah, do I end up with 200 or 400 12v amp hours"?
Old 12-21-2015, 07:11 PM   #2
2007 22' International CCD
200. It's the capacity at 12 volts which is two batteries on series.
KE4GNK/AE
Old 12-21-2015, 07:23 PM   #3
Nope. The amp hours would add only if the batteries are in parallel.
KE4GNK/AE
Old 12-21-2015, 07:24 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question 6+6-1=?
2 6v=12v in series....minus one 6v=zero v.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-21-2015, 07:28 PM   #5
Long Island , New York
The answer above was in reply to a post which I had just deleted after realizing it was incorrect -- thanks anyway rmkrum.
Old 12-21-2015, 07:42 PM   #6
1974 Argosy 20
Kooskia , Idaho
200 amp hours at 12 volts
Old 12-21-2015, 07:54 PM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Four Lifeline 6Vdc 300 amp-hour model 6ct batteries wired in both series and parallel will generate a 12Vdc 600 amp-hour battery capable of providing 300 amp-hours of power. These four batteries together weigh 368 pounds.
A comparable 12Vdv 600 amp-hour lithium iron phosphate battery is capable of providing at least 510 amp-hours of power. This battery weights 168 pounds.
Old 12-21-2015, 09:01 PM   #8
2007 27' International CCD FB
San Diego , California
^What's the cost difference between those batteries?
pteck is offline   Reply With Quote
Old 12-21-2015, 09:21 PM   #9
Full Time Adventurer
BoldAdventure's Avatar
Nomadic , USA
Just remember you can't use that full 200Ah, so in reality you have 100Ah.
6V batteries have a safe draw down rate of 50%.
Basically what Switz said in simpler terms.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 12-21-2015, 10:03 PM   #10
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
A lot. Just depends upon his much electrical power you "need" on a daily basis.
kscherzi is offline   Reply With Quote
Old 12-22-2015, 06:57 AM   #11
switz's Avatar
2014 31' Classic
Images: 8
Four Lifeline model 6ct (6 Vdc at 300 amp-hours and 92 pounds each) batteries were around $1,600 less than two years ago. The single 12Vdc 600 amp-hour lithium at 168 pounds) was around $4,600 this past spring.
The four Lifelines woulds provide 300 amp-hours of power while the lithium can provide over 510 amp-hours of power. Current caveat on the lithium is it can not be charged below 32 degrees, so ours is mounted inside under the front sofa of the Classic.
The smaller 300 amp-hour lithium is mounted under the street side sofa just in front of the wheel well on the 23D.
Old 12-24-2015, 12:21 PM   #12
1972 23' Safari
Norwalk , Connecticut
switz- where did you source your lithium batteries?
Widget is offline   Reply With Quote
Old 12-24-2015, 01:57 PM   #13
lewster's Avatar
Naples, FL , Hood River, OR
AM Solar
Old 12-26-2015, 09:30 AM   #14
switz's Avatar
2014 31' Classic
Images: 8
I drove twice to Eugene, OR to pick up our two lithium batteries. It was a two day drive each way. We did not have the thought of a second trailer at the time of the first trip.
starting in 2016. Thus the "freight" charge was very high to get the batteries to the installer.
AM Solar should be able to ship the lithium battery systems via truck starting in 2016. Far more cost effective.
Trailer Batteries 83Excella Electrical - Systems, Generators, Batteries & Solar 8 02-04-2013 10:57 PM
2 batteries outside and two batteries inside timmaah Electrical - Systems, Generators, Batteries & Solar 14 08-25-2011 07:18 AM
Batteries..All about batteries FrankR Batteries, Univolts, Converters & Inverters 0 07-17-2002 09:05 PM
Univolt/Dual Batteries uwe Batteries, Univolts, Converters & Inverters 4 06-28-2002 08:26 PM
Where should I install new batteries? Andy R Electrical - Systems, Generators, Batteries & Solar 3 03-31-2002 10:01 PM
