Old 09-06-2015, 06:43 AM   #1
1969 27' Overlander
Sun Lakes , Arizona
69 Overlander AC not turning on
We arrived in TN to pickup our 69 Overlander to find that the AC unit will not turn on. There is shore power to the coach.
My thoughts are to confirm 120v to the AC and 12v to the thermostat to start.
Then what?
Redleger is offline   Reply With Quote
Old 11-11-2015, 02:32 PM   #2
Reno , Nevada
Not sure of the A/C model in your Overlander, but if it has a "fan only" setting - does the FAN run without A/C?
In any case, your most likely candidates for failure to turn on are the "Start" Capacitor and "Run" Capacitor. The parts don't cost much. Good luck!
rickst29 is offline   Reply With Quote
Old 11-11-2015, 02:50 PM   #3
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
If it has the original Armstrong AC they are spoken very highly of. They are fixable if you have a good AC guy who knows what they are doing.
Also if it is an Armstong unit it does not have a 14" square hole cut in the roof. It has holes for the gas lines, power line, and blower motor shaft.
Does it look like a modern RV AC unit, or a metal box up there?
Silverflames is offline   Reply With Quote
Water heater switch not turning on/lighting red mizzadventur Water Heaters, Filters & Pumps 8 10-05-2015 07:49 PM
Battery Disconnect not turning on... ATE123 Sprinter and B-van Forum 13 04-06-2015 07:38 PM
Atwood gas hot water heater not turning off murphy Water Heaters, Filters & Pumps 2 06-27-2014 02:04 PM
turn signal light bulb replacement...bulb not turning ArgosyMinuet All Argosy Trailers 2 04-28-2013 09:52 AM
My 1975 Overlander lock won't open, it just keeps turning LucyPepper Doors & Locks 2 06-22-2009 06:36 PM
