Old 10-04-2014, 12:55 PM   #1
'68 Safari
Hi people. having finally hooked up a battery and checked the 12v system i hooked up the mains electrical system expecting a changeover switch or something, now in my safari there is a switch above the door, im not sure if its a changeover switch or not but when i switch it on a loud click in the main control panel is heard and the lights go out, but it resets after i switch it to off.
can anybody shed some LIGHT. on this. hehe!
beachbum73 is offline   Reply With Quote
Old 10-04-2014, 01:56 PM   #2
kokopat's Avatar
Hendersonville, NC , North Carolina
Here's a post with the electrical schematic... http://www.airforums.com/forums/f303...ram-82064.html
Like on my '68 overlander - it enables the overhead light in the kitchen. Sounds like you have deeper problems but the light could have a short circuit and is tripping the self resetting circuit breakers. There is no changer that I'm aware of.
good luck,
Pat
kokopat is offline   Reply With Quote
Old 10-04-2014, 02:08 PM   #3
Unless someone modified the electrical system, there is no changeover switch.
Old 10-04-2014, 02:09 PM   #4
thats interesting thanks, pretty much all the electrics i have tried work with exception to the AC and the gas/ electric fridge so im guessing there may be an issue there. the kitchen lights work fine on 12 volt, they have a three brightness switch on the actual light. thanks for the electrical link to wiring diagram.
Old 10-04-2014, 02:19 PM   #5
the link however directs me to FANtastic fan info!! shameless plug or mistake! lol
Old 10-04-2014, 03:06 PM   #6
surfpod's Avatar
1976 23' Safari
1962 22' Safari
1961 16' Bambi
Philly burbs , PA
try it again. Seems to work. I got the schematic.
surfpod is offline   Reply With Quote
Old 10-04-2014, 06:18 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your AC won't run on 12v. It requires 115v and likely 30 amps. You can test it on household 115v 15 amp in "FAN" position only. Don't command "COOL" as the low household power could damage the motor. (Honey, there is smoke coming from the AC, is that okay?)
Your 68 Safari is built with Airstream's "univolt" system, meaning everything in the trailer except the AC will run on 12v. The "univolt" converter will also charge your battery when plugged in to 115v.
David
dbj216 is online now   Reply With Quote
Old 10-05-2014, 03:30 AM   #8
i run my mains from a 16kva genset with a 56 amp supply 110v so its got plenty of juice, the reason why is that the UK runs 230v and i have no 110v feed. is there an owners manual showing you what switches everything on or off?
Old 10-05-2014, 07:46 AM   #9
The main circuit breaker will turn "everything" off.
Old 10-05-2014, 10:02 AM   #10
Yay! found the problem. which im embarrassed to admit but will tell all to let you know of any others that have no clue being TOTALLY GREEN to airstreams and starting with something thats older than me( not by much mind).
I had, when viewing said airstream actually played with the switch on the side which i think is inconspicuously placed!!! hehehe
it functions, with a refrigerant topup im sure will be freaking cold, as it was quite cool after about 10-15 minutes.
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 08:31 AM
22 safari sport vs. 20 safari jeffrho Member Introductions 10 01-04-2008 07:52 PM
Safari 19' vs Safari 22' michael165 2006 Safari 15 06-04-2007 06:02 AM
On a safari for our Safari 3DogNight 2007 Safari SE 10 12-21-2006 12:54 AM
Doing research-19' Bambi-Safari OR 23' Safari-WHY? ernesto ca Member Introductions 9 04-06-2006 06:33 AM
