Old 02-03-2011, 09:04 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
65' overlander power connector mod?
Currently our overlander has the 30amp power cord coiled in the one stop center behind the rear hatch. Problem is that when you hook up, the hatch needs to be off exposing the Convienence Center to the elements. The overlander also has a plate riveted on the street side that says "This connection is for 110-125 Volt AC service". What was this for? Would there be any wires behind this plate?
Could I install one of those marinco plugs in that location? I'd like to install something like this:
http://www.vintagetrailersupply.com/..._p/vts-660.htm
To do this project, would I cut the cord and hard wire into the back of the new marinco connector? Thanks for yalls input.
ID:	121333   Click image for larger version
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 02-03-2011, 10:23 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
No wires behind it. Just tells you the trailer is wired for 110-125 volts AC service. If this label is adjacent to the compartment where your wiring is or even if you have access to the area above and behind the label; I don't see why you couldn't install the plug. Leave the label on to identify the power requirements for the trailer.
AirRowan, Duramax install for Classic Power John H. Classic Motorhomes 48 07-19-2012 09:32 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
Progressive Dynamics Inteli-Power 4060 Power Center 68 Overlander Commercial Listings 0 01-21-2011 11:24 PM
