Old 02-12-2011, 09:06 AM   #1
Peggy Wilson's Avatar
1962 22' Safari
Kansas City , Missouri
Images: 11
'62 Safari electrical update questions
We would like to install a 12v converter and have several questions. (1.) What gauge wire is required from the converter to the battery? The original 'old style' battery was maybe a tractor battery. (2.) And should that be updated to a deep cycle marine battery? The old one is shot of course. (3.) When wiring from the converter to the battery are there distance limitations? We have a 22' trailer. The original system is 12 v and 110 running parallel. The original battery box is on the front of the trailer and our plan location due to size, to locate the converter under the couch which is mid way curb side. (4.) We are considering (if it would work) to take the 12 v from the converter and attaching to the trailer 12v electrical system. (5.) Would it work to 'back feed' to charge the battery from that location? Thus the wire gauge question. (6.) Should we consider 2 batteries? (7.) Is there a conflict to use a deep cycle marine battery and a tractor battery together? Whew! I thank anyone and everyone in advance if they have input on this situation!
Blog is: 62safariairstreamrenovation.blogspot
Peggy Wilson is offline   Reply With Quote
Old 02-12-2011, 10:59 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
The wire should be sized to match the output of the converter.
30 amps #10
40 amps #8
55 amps #6
70 amps #4
I'd aim for the smaller converters for this trailer. If the wire from the battery to the fuse panel is already large enough, wire the converter to the panel.
Yes... there's no point in using a starting battery. You don't need something really fancy in deep cycle batteries.
The sizes above are plenty adequate for an 12 foot run.
The trailer electrical system is fused at the DC panel. Your converter needs to be connected to the input in the fuse panel so that no branch circuit sees more that it's rated ampacity. You can do that by connecting it to the battery (sharing the existing wire), or by connecting it directly to the fuse panel.
Current typically flows to and fro in the lines to the batteries; this is normal. Remember that when the converter is on, current can flow into the battery and out to your lights, etc.
Depends on how much and how long you camp disconnected.... and how
careful you are w/ lights, etc. LED lights are a big win here....
It will work for a while; the tractor battery will fail first and
that won't help the other. In a pinch - sure - but it is definitely suboptimal.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-12-2011, 06:53 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It is difficult to nearly impossible to charge batteries in banks evenly. Since they may not have discharged equally one may require more charge time than the other resulting in overcharged batteries. If you have a method to isolate one battery form the other while charging the results will be better.
Old 02-12-2011, 08:23 PM   #4
Central , Mississippi
- Bart
believe it or not...some of these old ones don't have a fuse, much less a panel!
The only real way to add one is fuse it as you suggest, and tie it to the battery (if THAT was even an installed option!)
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
battery, converters, wiring
Our '56 Safari (aka Our Retirement Home) SafariSteve 1956 Safari 41 09-04-2013 06:55 PM
1967 Safari - Basic electrical - photos attached denverdingo Electrical - Systems, Generators, Batteries & Solar 12 10-19-2011 12:33 AM
1968 Safari 22' :: 1968 Airstream Safari Darrengj Airstream Registry Discussions 0 08-19-2011 09:32 AM
Safari :: 2006 Airstream Safari SE Mrs Silverback Airstream Registry Discussions 0 08-19-2011 09:31 AM
