Old 08-16-2005, 07:41 PM   #1
'62 Globetrotter - Re-thinking the electrics...from scratch
Well, I got my '62 GT, and I'm quite happy, but it's going to need a lot of interior and systems work. It looks like the electrical system will need close to a complete overhaul, and I'm wondering if I should rethink the 12v/120v split.
Here is the deal, this is not intended to be a mobile airstream, rather a semi mobile cabin on some land far from any type of hookup (ac/sewer/water) The only AC this might see would be a small portable generator, the only DC it might see might be a solar cell. Looking at what's there, I could not find anything looking like a univolt. Unless it's buried under the floor, or in the wall, it's gone, or was never there. (It kind of looks more like there never was one, all the light fixtures are doubles...one 12v and one 120v)
The question is do i really want to maintain the split system? I don't know what's out there (or what I can afford) but here is my ideal system, tell me if it can be done, or if performance would be lousy:
- all internal systems 120v
- a couple of heavy duty batteries connected to an inverter supplying AC to all the plugs and lights in the trailer
- a solar cell to recharge the batteries when I'm gone during the week
- a gas generator that could simultaneously supply AC when hooked up and charge the batteries with any excess current.
- ok, this is a little pie in the sky, but wouldn't it be cool if the generator started itself up when the batteries got low? Probably real expensive.
Has anyone tried something like this? Here are some of the questions that immediately jump out at me:
-Are 12v lights significantly more energy efficient than 120v coming through and inverter? Should I keep the 12v in place for the lights?
-What type of batteries are ideal for this type of application? How many might I need to mostly last a weekend without help from the generator. It would probably run a small dorm fridge (unless I splurge for a LP model) lights, and recharge my laptop.
thanks for all the help.
Geof
'62 Globetrotter
abruzzi is offline   Reply With Quote
Old 08-16-2005, 10:26 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Your trailer never had a charger/converter from the factory. It was equipped with a abttery and dual voltage lights, and a split of 12V or 12V fan motors. The battery would charge while driving and then allow use of 12V lights when not hooked up for a day or so. The 120V sode would work of course, when plugged in, so would the wall outlets.
Inverters eat power as they are working, as they do not have a 100% efficience. There'smuch written aboutthis subject, which a forum search would reveal.
Well, it's like permanent boondocking. A converter/charger with a good quality battery pair will give reliable service when charged a few hours a day by use of a small generator. Solar is great, but expensive and relies largely on sunshine. But once installed, it's free energy. Which is best for you depends on how much you will use the trailer, and on your personal preference.
Yes.
Use LP for the refrigeration, then 2 12V batteries will last a week id used conservatively. We have boondocked in Baja for 5 days at a time with just one battery.
Uwe
www.area63productions.com
Old 08-17-2005, 09:29 AM   #3
So keeping my 12v lights in place seems to make sense. For the charging system, one of these seems to be a pretty decent option:
http://www.spacecentersystems.com/ca...ucts_id/254303
It would certainly simplify the complexities of connecting an inverter, converter and charger into the same system. Is this approach common?
Geof
Old 08-17-2005, 10:36 AM   #4
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
1000W won't take you very far, is the problem.
Uwe
Old 08-17-2005, 11:20 AM   #5
Actually, I calculated that my AC needs would rarely peak 600w. I'm not looking at a full "home away from home". Possible uses are:
- Recharge Laptop 65w
- Small dorm fridge 300w (intermittent)
- Portable swamp cooler 60w
- Portable stereo 30w
I'm not sure what else I'd use. No TV (a good thing.) Maybe a 300w blender for very occasional use. The Tripplite will sustain 1500w for an hour.
Geof
Old 08-17-2005, 11:25 AM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Geof
Geof,
I have a 12V charger for my lap top, just used a regular 12V outlet. Also Black & Decker makes a battery operated blender which uses their rechargeable interchangeable batteries.
Bill
Just my personal opinion
64 Globetrotter Stove Vent Cover Trotter Roof Vents, Skylights & Fans 2 12-15-2007 06:03 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 01:27 PM
Removing Scratch with 1200 Grit Paper Jim Clark Cleaning, Stripping & Polishing 4 10-13-2002 06:51 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 09:41 PM
