Old 05-03-2002, 12:43 PM   #1
sbboyd's Avatar
Question 62 Bambi Battery
I recently aquired a 62 Bambi w/ no Battery. There doesn't seem to be any connectors in the back compartment (where the water heater is). There is a narrow aluminum mounted compartment in the front (above the gass cans) that has a little blach and a red wire and two loose battery connectors, but the compartment is not big enough for a standard size battery. Has my trailer been customized? Any ideas?
sbboyd is offline   Reply With Quote
Old 05-03-2002, 01:38 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
What's the dimention of the compartment? Height, width, and depth
>>>>>>>>Action
Old 05-03-2002, 01:51 PM   #3
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Could that battery location be for the breakaway switch for the brakes?
Also if you don't have it, User Manuals are available for purchase from:
Helen Davis Secretarial Services
PO Box 484
Sidney, OH 45365
(937) 492-8885
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 05-03-2002, 03:36 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
The owners manual I have for 1966 shows the battery and univolt access door for single axle trailers on the street side just in front of the axle. Also found there are electrical and water connections. Not sure if that helps on your 1962.
I ordered my owners manual from Helen Davis. Also note there is no service/shop manual for any years in the 60's or older.
>>>>>>>>>>>>>Action
Old 05-20-2002, 09:22 AM   #5
The battery you are looking for is a 12V forklift type battery, which can still be purchased today. It is long and narrow and fits in that front compartment you described.
LR
61BambiCanada is offline   Reply With Quote
Old 09-20-2002, 07:33 AM   #6
kzener40's Avatar
Images: 14
I have a similar question. My 56' Bubble came with a home made battery box attached to the front of the hitch (in front of the gas tanks). What seems odd to me is it appears all of my interior lights are 110 and I don't seem to have any 12v lighting on the inside. Was that typical in 56'? Does anyone know if originally there was a battery on the unit and if so where it would have been located. Not sure what it would have run since there doesn't appear to be anything in the unit that works off of 12V. I have a 110 type plug on the front of the trailer that sends power to an old glass type fuse box. I'm told my Bubble originally had an Ice Box (so I guess it didn't need electricity?), a long narrow gas heater, and an stove and oven. No 12v electric water pumps or hot water heater. So does that mean back than 12V wasn't used (except for the exterior trailer lights)?
kzener40 is offline   Reply With Quote
Bambi '62 seeking Bambi '62 for..... Rosemary 1961 - 1963 Bambi 12 07-09-2013 10:53 AM
Vintage Bambi battery hookup & DC questions Rosemary Electrical - Systems, Generators, Batteries & Solar 6 12-25-2003 11:11 PM
Towing '62 bambi with a VW Marshall44 Tow Vehicles 3 03-14-2003 06:43 PM
Pictures Of Original '62 Bambi? Marshall44 General Interior Topics 2 03-10-2003 08:55 PM
61 Bambi Battery 61BambiCanada Electrical - Systems, Generators, Batteries & Solar 0 05-21-2002 10:53 PM
