Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 06-24-2006, 06:53 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
'60 Ambassador 12vdc panel
I'm trying to make heads or tails out of the DC panel in my '60 Ambassador. It consists of several wires and two glass 20amp fuses. I had to remove many wires that a PO added.
There are two white ones screwed to the wall which are grounds of course. I've identified one that powers all the 12vdc lights and the two ceiling fans.
I also tried to identify the wire the should come from the battery compartment up front but could not locate it near the fuse panel.
In the picture there are three black wires to the left of the fuse panel. The one closest to the panel powers the lights. I cannot identify the other four black wires.
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 06-24-2006, 06:59 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Tim, do you have access to a power probe? This tool lets you power up wires, and check to see if they have power, or continuity, and come equipped with a 10 amp internal circuit breaker.
With it, and a 12v power source, you can power up those wires, and see what comes on in the coach without extreme danger of causing further damage.
http://www.powerprobe.com/
(No Longer at Inland RV)
Old 06-24-2006, 07:10 PM   #3
Safari Tim's Avatar
Images: 35
Thank Terry,
That is basically what I did. I have a digital volt meter, 12v test lamp and a power supply. I powered them up and the one wire powered all things 12v in the trailer.
So now I am just trying to figure out what the rest do. I assumed one should be a RV battery feed to the fuse panel, one should be a 12v feed from the tow vehicle to charge the RV battery while under tow. I could not verify this with my ohm meter though. And it would not tell me what the other two black wires were for.
-Tim
Old 06-24-2006, 07:22 PM   #4
Well-Preserved
Ugh. Our Overlander had a similar setup, only with a pair of self-resetting 20 amp circuit breakers instead of the glass fuses. Trial and error found the charge line had broken off inside the belly pan, and the 12v+ lead from the battery was nipped off just inside the battery compartment. Everything in the trailer runs off that one little wire. I have managed to split the trailer iinto two halves electrically, with 15 amp spade-type fuses. If I do more, it will require ripping out panels and rewiring everything, a step I am not willing to take right now.
Old 06-24-2006, 07:49 PM   #5
Safari Tim's Avatar
Images: 35
Thanks Terry,
I had not considered a broken wire from the battery or charge line. Silly me, expecting 46 year old stuff to work ;-)
I will probably be removing a big enough section of the belly pan to add a grey tank some day. Maybe I'll add some more DC convience circuits then going under the floor and up through the appropriate cabinets.
Anyway, thats in the future. Got to figure out what I have now ;-)
Thanks for the info.
-Tim
Old 06-24-2006, 09:26 PM   #6
Shacksman's Avatar
Profile:  1967 22' Safari
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Hi Tim;
I picked up a 60 Ambassador International last weekend. We stayed at Rob's place for awile, while we sorted out the paperwork to get it over the border.
I have started at the other end, taking apart the bathroom to update the plumbing. So far it's better then exected no major floor rot. I haven't tryed out the 12 volt yet. It looks like your picture. I'll hook up a battery tomorrow and see what happens.The 120 works OK so far. We are going down the same road it seems, so keep in touch.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 06-24-2006, 09:38 PM   #7
Safari Tim's Avatar
Images: 35
Hey Doug,
Yep, I heard about your purchase. I think you made out a little better than I did ;-)
I pulled out the conservativly challenged dinette benches a PO made in mine. Removed 90% of the glued down hardwood floor. Yuck! So I could check for rot. So far so good. Only one 2" section near the jouise window by the door.
I hope the backend is as good as yours!
Humm.... guess I better better get my old parts on eBay before you do!
-Tim
Old 06-24-2006, 09:55 PM   #8
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Tim, I need the burner for the Bowen water heater. For some reason it's missing. It holds water so I don't know why someone would remove and lose the burner. Must be lots of them thrown away when replacing the heater just to find one now.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Old 06-24-2006, 10:15 PM   #9
Safari Tim's Avatar
Images: 35
Well, you're one up on me. I don't even have the Bowen in mine. Someone replaced it with a small residential unit...
-Tim
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Control Panel indicators smily Electrical - Systems, Generators, Batteries & Solar 3 07-26-2002 03:55 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
Display Panel ALANSD Mechanics Corner - Engines, Transmission & More... 4 06-08-2002 03:28 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
