Old 06-27-2009, 05:02 PM   #1
new york , New York
59 Tradewind 'City Power' electrical problem
The atached photo tells the story. The Back wire needs to be attached to a terminal to make thie city power work.
We cannot figure out where. Can anyone help?
Thanks in advance
Stephan
xposure285 is offline   Reply With Quote
Old 06-27-2009, 06:16 PM   #2
Ronald D
1965 26' Overlander
Welshpool , New Brunswick
It appears the wire must be attached to one of the lugs that have the jumper between them. One of the lugs must be loose to allow the wire to be free.
Ronald D is offline   Reply With Quote
Old 06-27-2009, 06:55 PM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Hi ~
First off, we need to figure out where that black wire is coming from. Do I see that it is coming out of the incoming shore power plug from the outside of the trailer? It is too new looking to be original and thus means a PO (prior owner) put it in. Anything a PO did is suspect and you'll need to see how the shore power plug is wired. Start there. Please post a picture of what that looks like. Is it the original Bargman connection with the metal flip up spring loaded door? Those breakers aren't original looking either. If yours is a California made TradeWind, it should have a Bulldog electrical panel and the breakers for those are still available. Do you still have the panel cover?
So tell us about this '59 TW of yours.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 06-28-2009, 11:36 AM   #4
new york , New York
59 tradewinds "City Power" electrical problem
Brad,
Thanks for response.
I have attached a revised hi res. for you to check out.
There is an old b30 amp breaker siting on the floor that fits the back slot. The dual 20 amp does not snap onto the pole.
I've attached photo of the plate.
Genearal info: It has original keys, I'm second owner! I have just taken out and replaced entire floor. Will need some help locating some fixture and fittings cabinets are mint! Fridge and cooker good shape bathromm is good noow new floor is in. Has double bed not 2 twins.
I'll send you some photos of the TradeWinds later this week.
Need electrics, because it's getting to warm to work on it!
Best Stephan
ID:	83036   Click image for larger version
Old 06-28-2009, 12:45 PM   #5
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That dual 20 amp isn't the right brand to snap into the panel. What does the outside shore power plug look like and have you checked out how it is wired up? You'll need to know which wire is for hot, neutral and ground. The green wire showing is the ground to the shell, the white wires that go into the wall are for the outlets so now its just figuring out the wires that come into the box and how to wire them to the distribution panel. I believe the black should hook to the bottom leg of the one where the green wire is screwed in but I would recommend you find the right breakers that fir that panel so you can button it up by putting the original cover back on. Pretty certain it won't if it has the wrong breakers in it.
I have a loose one I could shoot you a picture of so you have something to find. Probably has some numbers on it too. I'll check later when I get home from work tonight.
FF
Old 06-29-2009, 07:49 AM   #6
new york , New York
59 tradewind city power problem
Did as you recommended and removed the twin braker, what sould I do with the 2 black wires that went into the twin braker?
Have attached more photos.
Old 06-29-2009, 08:34 AM   #7
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Your photos didn't come through. Please re-post.
FF
Old 06-29-2009, 03:33 PM   #8
Ronald D
1965 26' Overlander
The distribution box pictured is a 220 volt, two pole box. The jumper wire between the two lugs is there to distribute 110 volts to both sides of the box. There is no 220 in sight. The tandem 110 volt breaker pictured will work fine if it fits the bar, I think it might be a Murray (as they were color coded, blue--15 amp, red--20 amp, green--30 amp.etc) If that breaker does not plug in you need to find a General Electric tandem.
The cover should go back on just fine. Seeing as there is no 220, there is no need for a 2 pole breaker, just single pole or tandem single pole breakers (as shown). Wire coming in from plug should be three wires--green-ground, white- neutral, black- hot. The ground (green) and the neutral (white) should go under the screws on the right side, the black (hot) goes under either lug and distributes 110 volts to both sides.
Old 06-30-2009, 11:43 AM   #9
new york , New York
Thanks for your reply. Just for clariffication i have attached a photo with all lugs and screws labelled. If you can say what goes where that would be great. I will purchase the GE breaker today if I can find somewhere that stocks it.
Old 06-30-2009, 11:50 AM   #10
new york , New York
flyfshr
Find photo's attached.
ID:	83227   Click image for larger version
Old 07-01-2009, 10:20 AM   #11
Ronald D
1965 26' Overlander
The first picture shows a cap with three wires, looks like black and two whites. First of all, this should be a cable, three wires covered by a black rubber type insulation. The cable type is called SO or SJO. You should ask for 10/3 SO or SJO when buying it. Get a comfortable length, 30 feet? Get a cord cap for it at the same time and install the cord cap black wire on gold screw, white wire on shiny one, green wire on green one. In the panel put the two black wires that were on the tandem breaker and put the tandem breaker back in, insert the bottom first and plug the top into the buss. Put the cable into the box using a 3/4" or 1" romex connector to connect the cable to the box, put the black wire onto either one of the lugs at the top of the box, tighten both lugs. Install the white and ground wires to the four screws at the bottom right. ( the way it is now, if you plug that in there is a dead short circuit) Put the cover back on and everything is done.
Ron
Master electrician (Massachusetts) since 1971
Old 07-01-2009, 10:47 AM   #12
new york , New York
Ronald,
Thanks again for this. I just want to make sure I understand as I am NOT a master electrician. Most odf you instructions are very straight forward.
Questions:
Currently the Earth wire from the cap is attached to th scew at thevery bottom right of the box. You're saying it belongs on one of the bottom of the 4 screws where the black cable is currently attached.
The current tandem breaker does not fit on the buss . Should I buy a GM tandem breaker so that it fits Is there a model number?
Old 07-01-2009, 10:48 AM   #13
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Now he sounds like he knows what he's talking about. Follow his directions and let us know how it comes out. You need some electricity in that TradeWind.
Let me go look at my extra breaker for a number. Can you post a picture of your panel cover?
FF
Old 07-01-2009, 01:37 PM   #14
new york , New York
here it is.
Electrical Problem QuietWater Airstream Motorhome Forums 11 06-22-2009 12:06 AM
Electrical problem - 1965 Dr JJ 1965 - 1969 Globetrotter 3 06-17-2008 01:13 PM
City/Battery Power Switch Broken? '63 Safari DenverAaron Electrical - Systems, Generators, Batteries & Solar 8 10-06-2006 10:32 AM
How Long without City Power The Flintstones Generators & Solar Power 7 09-27-2006 02:02 AM
Electrical Problem NASCAR345 Airstream Motorhome Forums 15 03-13-2003 07:23 PM
