Old 11-30-2004, 08:15 AM   #1
cdmagda's Avatar
Images: 51
'58 Flying Cloud re-wire
I am re-wiring the AC system and would like any input on best location of breaker box, type of wire, ect... thanks.
cdmagda is offline   Reply With Quote
Old 11-30-2004, 08:46 AM   #2
Images: 59
If you're fussy, the main breaker box has to be within 18" of where the shore power enters.
I'm using a wire called MC-lite for 120vac. It is THHN wire inside alumuminum armor, with a mylar wrap. What I like about it is:
1. It's cheap (12-2 w/ground) $28/100 ft
2. It has a ground wire
3. It fits through a 1/2" hole
I'm also using shallow blue plastic junction boxes for wiring. They are 1 1/4" deep and fit inside the wall. They cost $0.75 each.
For 12vdc I think stranded wire is the best option.
Flying J Propane Question Pick On The Road... 5 10-26-2002 05:46 PM
Extra wire susan martin Batteries, Univolts, Converters & Inverters 3 09-21-2002 07:52 AM
Replacing wire harness Les Gilliam Batteries, Univolts, Converters & Inverters 4 08-19-2002 08:25 PM
Check , Check and Re-Check a new refer saga. thenewkid64 Refrigerators 13 06-24-2002 09:54 AM
