03-03-2017, 02:06 PM
1956 22' Flying Cloud
Valencia
56 kitchen vent fan
Has anyone had any luck finding a replacement fan for the sidewall kitchen vent. Presently looking for one for a 56FC.
Thanks !
03-03-2017, 02:10 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
I bought this one . . . had to modify it significantly to fit in 1-1/2" wall . . . or you can build a "collar" like they suggest
http://www.vintagetrailersupply.com/...-p/vts-391.htm
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
03-04-2017, 05:26 PM
Valencia
Thanks for the info ! I should have said fan motor... But buying that whole fan and just using the motor would be a lot cheaper than having the existing motor rebuilt .
03-04-2017, 06:19 PM
1966 22' Safari
Fredericksburg
Search Google "ventline rv sidewall exhaust fan". Ventline has a pretty good line of assembled units. Don't know if they sell the motor separately. When I looked at their site, the entire assembly wasn't that badly priced. Maybe use the motor out of their unit. Good luck.
03-04-2017, 06:40 PM
1966 22' Safari
Fredericksburg
56 Flyg Cld- I don't see you on the "Captain Jones Flying Cloud Registry". If you give me your VIN I will enter it on the list. You can access all FCs on the list by going to his thread. Thanks
03-05-2017, 12:12 PM
Valencia
Thanks Bubba, I will take a look at their site. See your thread you added me to the registry already...
03-05-2017, 02:57 PM
1966 22' Safari
Fredericksburg
Sorry 56, you are correct and we had added you earlier. When my mind is wrapped up in plumbing grey water tanks, I tend to forget other things. Good luck on the fan motor.
03-06-2017, 09:45 PM
Valencia
I'm in the process of ordering my grey water tanks now. I get wrapping your head around the plumbing..
03-16-2017, 09:57 AM
1955 22' Safari
Laredo
Replaced motor
I replaced mine with one from Amazon:
Same blade diameter but slightly longer shaft so I offset the interior guard slightly.
03-17-2017, 02:32 PM
Valencia
Thanks Bambi Tex, Although I didn't purchase the same one I used your link and found a Broan motor I believe will work. Thanks Again!
