Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 02-04-2005, 11:23 PM   #1
Profile:
55 Overlander wiring
Can anyone give me a primer on how a 1955 Overlander was wired up?
William8979 is offline   Reply With Quote
Old 02-05-2005, 03:23 AM   #2
TomW's Avatar
Profile:  1967 26' Overlander
Huntsville , Alabama
Schematic from '67 Overlander
The idea will be the same although the implementation will be different:
http://www.knology.net/~tcwilliams/i...wVoltPanel.jpg
http://www.knology.net/~tcwilliams/i...calDiagram.jpg
General insight (no aluminum wire in yours):
http://www.knology.net/~tcwilliams/Electrical.htm
(The "insert hyperlink" function is not working at present)
Tom
Old 02-07-2005, 09:38 PM   #3
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Airstream Registry
Greetings William 8979!
As an addition to what Tom has already posted, I might add the following. Depending upon the extent of modification performed by previous owners on your 1955 coach, you will likely find at least some of the following to be true of your coach.
1.) Your coach would not have left the factory with a Univolt (or any power converter for that matter). Univolts did not become factory equipment until later in the 1960s - - if my notes are correct, 1964 was the first year that the Univolt was a standard feature.
2.) The coach actually had separate 12-volt DC and 120-volt AC light fixtures, and there may have been a separate umbilical cable just for these lights on your coach at one time (this extra cable is one feature that has often been changed-out by previous owners).
3.) The 12-volt side of the electrical system would have been powered by a 12-volt battery that was typically mounted in an aluminum box centered below the front window behind the LP tanks (it wasn't a typical Deep-Cycle battery as we know now), it was a farm implement starting battery that is still available through parts stores that carry farm implement batteries.
4.) There is a probability that you will find the 12-volt fuse panel behind the front lounge, and it may be hidden by an access door. On the later 1950s through the 1960-61 models that I have seen, the 12-volt fuse panel utilized what appear to be typical household screw-type "glass" fuses.
5.) There will likely be individual power transformers located near the furnace and the air pump for the water system - - these will usually be accompanied by a switch that must be thrown when power is switched from battery to shore power.
6.) If it hasn't been changed, your coach originally had a Bargman 120-Volt
AC power connection on the exterior of the coach that is almost impossible to replace in today's environment. If you have the original shore power cable and a working receptacle on the coach, it is something that needs to be handled carefully as the modern replacement will be much more obvious than the OEM Bargman assembly.
If your coach has escaped without significant changes, the refrigerator may be either strictly LP gas or possibly ice/120-Volt AC Electric. Again, this is a feature that often has been changed on a coach that is 40 or more years of age.
Good luck with your research!
Kevin
Kevin D. Allen
AIR #827
Old 02-08-2005, 07:20 AM   #4
greg176's Avatar
Profile:  1961 26' Overlander
Gabriola Island , British Columbia
The DC electrical in my '61 was all on one circuit which runs down the ceiling and pigtails off to everything.I attached a diagram on this thread.
http://www.airforums.com/forum...ad.php?t=13448
greg176 is offline   Reply With Quote
Old 02-08-2005, 09:49 AM   #5
Jabba's Avatar
Profile:  1955 30' Liner Commodore Vanderbilt
Wayne County , Michigan
Is there something specific you were wondering about? Our 30' has the 110V fuse block at the rear, with a branch of circuits running down each side of the trailer. The 12V fuse block is up front under the couch and runs down the streetside.
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
2-door Overlander InsideOut 1958 - 1963 Overlander 0 08-30-2002 08:14 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
Looking at a 64 Overlander N80 1964 Overlander 1 06-02-2002 08:25 PM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
