Old 05-19-2014, 06:25 PM   #1
2014 27' FB International
Macon , Georgia
50A Cable Storage
I have a 27FB International. My only exterior storage is the front compartment under the bed and the rear bumper storage which gets wet. The 50 amp cable is huge and heavy. I would be interested in anyone with this arrangement where/how you store this cable. I thought about some kind of plastic storage box but it will be difficult to maneuver it into the front compartment. Suggestions?
Roadtech is offline   Reply With Quote
Old 05-19-2014, 07:35 PM   #2
JimGolden's Avatar
1977 31' Excella 500
A Bag?
I have a 30 foot chord and a 15 foot chord. I keep them both in large tupperware type boxes under the dinette.
If your space is an odd shape, maybe you could coil your chord up and stick it in a bag of some kind, so that it could more easily conform to the shape of your storage area. I'd recommend cloth or burlap or something breathable, so that if your chord isn't 100% dry when you stick it in there, it would dry out. Heck a Southern States grass seed bag might be perfect. Simple and cheap.
The 50 amp chords are a bear, but it's nice having all that power! I converted my rig from 30a to 50a and never looked back
Best of luck,
- Jim
JimGolden is offline   Reply With Quote
Old 05-19-2014, 08:03 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Here's what I did for my 30-amp cord and my freshwater hose:
Gecko's Toes - Photo Gallery - Make it Mobile
It works well, BUT you have to buy the "air hose" size Gecko Toes® for a 30-amp or 50-amp cord; the extension cord size is too small for a cord that thick. Three Gecko Toes of the appropriate size, a large plastic cutting board (12×17 is what I used), some screws, a drill. That's all you need. Get a cutting board with a handle built in, and you can mount a dual coat hook somewhere to hang it from.
I also found that while the water hose can be wound on from the center outward as shown in the link, the shore power cord works better if wound from the outside toward the center.
Cats and ultraleather Airstream upholstery don't mix!
Old 05-19-2014, 08:33 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
I have a 30a cord with a 50a Marinco end on it that fits the trailer and carry that in addition to the 50a cord. I only get the 50a cord out when it's necessary and when there is 50a available. The 30a cord is much more manageable and was well worth the money.
Might be something to try then you can put the 50a cord wherever you can fit it without as much regard to ease of access.
Old 05-19-2014, 08:47 PM   #5
richinny's Avatar
2011 34' Classic
for a 50a cord i've been playing with a few containers. the oblong milk crate might work but the square one required too much bending. i'm thinking of a laundry basket next. i put the step in and toss it just inside the door so less bending is required. usually the first thing i want to do is get power hooked up for heating/cooling and to get the converter going. i bought a 30a to 50a marinco adapter from home depot so i could use my 30a cord for those quick overnight stops.
Ricky
Old 05-20-2014, 05:30 AM   #6
Skater's Avatar
1995 30' Excella
Bowie , Maryland
It's okay for the cord to get wet...after all, you're probably going to use it in the rain, right?
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 05-20-2014, 05:43 AM   #7
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
How about a zippered duffle bag?
Old 05-20-2014, 08:13 AM   #8
1987 25' Sovereign
Oregon , Ohio
If your tow vehicle is a pickup truck, how about in the bed of the truck.
msmcv51 is offline   Reply With Quote
Old 05-20-2014, 08:47 AM   #9
Macon , Georgia
I thought about that, but didn't think it would be good to sit in water for any period of time.
Old 05-20-2014, 08:50 AM   #10
Macon , Georgia
That's part of my problem, my tow vehicle is a Suburban.
Old 05-20-2014, 09:00 AM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
My Furrion 50a cable was on the better side of $400. I wouldn't chance that to the openness of a pickup bed. I use Duffel bags for everything. I keep a short cable, dogbones, testers, gender benders and the like in one bag, a 30amp in another, and my whopper 50amp cable on yet another. I tow with an Excursion, so everything is at at the ready in the back.
I have also made a "cheater cord", that being a cord which is 30 amps on one end, and 50 on the other. The 50 amp end has the 2 hot legs bonded so everything inside will work. I just have to remember not to rev everything up at once. My Excella has an outside cord reel where I keep this one stored for quick deployment.... also eliminates the use of adapters which I despise!
Old 05-20-2014, 10:12 AM   #12
2005 30' Classic
Burlington , Ontario
We have used the bumper storage tray ever since we got our AS about 5 years ago. We use it for 30 amp extension cable, water hose and extra hose, outside rubber door mat, and a few other things. never really had any problem with water - and if these items got wet, I can't imagine it would cause any problems. For me, the pull out bumper tray has been a perfect location for these things.
Brian.
Old 05-20-2014, 10:42 AM   #13
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Immersed in water, probably not. But if it's just randomly getting wet then drying, I wouldn't worry about it. Our rear bumper drawer gets wet, too (I have dreams of stripping off the carpet on it and spraying it with truck bedliner before it rusts out), and that's where I keep our extension cord, freshwater hoses, sewer hose, etc.
The cost of those cords is making me glad our camper is only 30 amp. Wow.
Old 05-20-2014, 11:14 AM   #14
Wise Elder
Jammer's Avatar
2010 30' Classic
Having the ability to cool our trailer even in extremely hot, humid weather makes it worthwhile.
The reduced cost and hassle that comes from fewer propane refills makes up for the cost and hassle of the cord, since due to quirks of the RVIA/NEC code, manufacturers can't install an electric water heater without 50a service.
50a AS at a 30a campsite bunni Electrical - Systems, Generators, Batteries & Solar 4 09-02-2013 06:05 AM
Where the heck is the 50A fuse in a '73 Ambassador??? CF Av8or Batteries, Univolts, Converters & Inverters 3 06-25-2012 04:24 AM
50a kb0zke Electrical - Systems, Generators, Batteries & Solar 5 07-27-2011 07:57 PM
50A only? 42570 Electrical - Systems, Generators, Batteries & Solar 13 09-27-2010 02:30 PM
30A to 50A cord? Bambi_Bandit Electrical - Systems, Generators, Batteries & Solar 9 02-04-2009 03:57 PM
