Old 07-26-2011, 08:29 PM   #1
Sioux Falls , South Dakota
50a
When did Airstream switch from 30A to 50A electrical service? Was it done across the board, or top of the line the first year, next level the next year, etc.?
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
kb0zke is offline   Reply With Quote
Old 07-26-2011, 08:34 PM   #2
jdalrymple's Avatar
2009 27' FB Flying Cloud
1982 31' International
1991 35' Airstream 350
Jay , Oklahoma
Not all AS are 50 amp. Typically, units with two a/c units from the factory are the ones wired for 50 amp service. Although other options like electric water heaters and the like may require 50 amp service too.
Jeff & Cindy
'09 27FB Flying Cloud;'82 31 International
'91 350 LE MH; '21 Interstate 24GT
Old 07-26-2011, 08:38 PM   #3
Always learning
Lance M's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Lance M
Not all are 50a. The long trailers with two ACs are 50a. All others are 30a standard.
Lance
Lance M is offline   Reply With Quote
Old 07-27-2011, 12:17 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
As others have noted 50a service is only installed on rigs with dual air conditioners.
I have heard that the first few rigs manufactured with dual air had 30a service. It's possible to run both air conditioners from a 30a shore power connection as long as there are no other loads. When I am stuck doing that I even run the fridge on propane to avoid popping the pedestal breaker.
On rigs with single air conditioners it is possible to exceed 30 amps if you run the electric water heater and the air conditioner at the same time, plus a few other loads. But Airstream doesn't offer 50a service for these trailers unless you also get the dual air conditioning.
Old 07-27-2011, 07:39 PM   #5
We're more interested in the longer coaches anyway, and dual air is almost a necessity for us. Since everyone else has long since gone to 50A service, I assumed that Airstream had, too.
AIR 54240
Old 07-27-2011, 07:57 PM   #6
jdalrymple's Avatar
Jay , Oklahoma
I don't believe there is any universal switch to 50 amp. I do agree that folks seem to want more and more electrical items in their RV of choice which may require 50 amps, but there are still a lot of new units with only 30 amp service.
I have seen several 34' Airstreams with second Air Conditioners added with a separate 20 cord to power the added AC. This eliminates the need to make changes to the main breaker box.
Best Regards,
Jeff & Cindy
What services will i find? Darkspeed On The Road... 9 06-09-2011 10:43 AM
Power cord length-recommendations? SilverHoot Electrical - Systems, Generators, Batteries & Solar 17 01-23-2011 02:39 PM
