Old 06-12-2007, 08:40 AM   #1
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
50 and 30 amp shore power
I am preparing to do a system upgrade to my '72 Safari. At present it has a 2 each, 20 amp breaker box. I want to replace this with a 30/20/15/15 setup to accomodate some more outlets and changes I want to make. One of the things I want to do is to add an outside shore power plugin and eliminate the power cord coming out of the bumper storage box. My concern is this: since many campgrounds have both 30 and 50 amp service, should I make the new plugin a 50 or a 30 amp capability? And, if I go with the 50 amp, will I be able to utilize 30 amp if that is all available and vice versa? Pros and cons please. Thanks, TB
tinbender is offline   Reply With Quote
Old 06-12-2007, 08:48 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
I saw an odd thing last week at Mississippi Palisades S.P. south of Galena, IL. Some sites had boxes with a choice of 50A or 15A only. Most had all three -- 50A, 30A & 15A. Lesson is that I need to get a 30A-50A adapter for my 30A shore power cord.
5 meter Langford Nahanni
Old 06-12-2007, 08:50 AM   #3
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
I'm no expert here, but from my campground research, it seems like 30 amp is more available than 50 amp. My Airstream came with an adaptor that converts the 30 amp plug to a 20/15 amp plug if that's all that's available. I also bought a 50 amp to 30 amp plug converter at Camping World. So, I'm ready for anything--I think.
Randy
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 06-12-2007, 09:21 AM   #4
Images: 59
I put 50A/240V in my '59 Tradewind. It's better to have enough than not enough. Can always go down to 30A is that's all that's available.
The only downside is the shore cable is pretty pricy.
Also, if you put in 50A/240V, make sure the two legs are balanced.
Old 06-12-2007, 02:52 PM   #5
tinbender's Avatar
2001 16' Bambi
50 amp/30 amp -- 2 legs balanced
Thanks for all the replies and good info. It seems as if I can adapt it any way need be if what the trailer has doesn't match the supplied hookup. I just want to equip it with what will serve best for the long run.
Markdoane -- I am sorta leaning towards going with the 50 amp for now. I am getting an electrican to help me with this upgrade. I will assume that he will understand what is meant by "making sure the two legs are balanced" on a 50 amp, but you can educate me on that if you will.
Thanks much to all, TB
Old 06-12-2007, 04:18 PM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
Unless you intend to use 3 or 4 1500 watt heater to grow pot in your trailer I can not see any reason to install a 50 amp service.
One thing to consider. Even if you are only using a total load of 15 or 20 amps with everthing on in your trailer most campground will charge you extra for a 50 amp service. You may remember 10 or 15 years ago when campgrounds charged extra is you came in with an AC on the traile even oncooler weekends.
2004 Excursion 4x4
Old 06-12-2007, 04:42 PM   #7
Images: 59
If you put in a 50A/240V service, you really have 100A service at 120V. Very useful if you have an air conditioner, electric water heater, hair dryer, electric skillet, and some heavy duty grow lamps for your agricultural hobbies.
The two legs don't need to be perfectly balanced, just reasonably balanced. Don't put the A/C and large dishwasher on the same phase. Basically, just put a little thought into it. Your electrician will know how.
NEC 551.42 Branch Circuits Required.
(D) More Than Five Circuits Without a Listed Energy Management System. A 50-ampere, 120/240-volt power supply assembly shall be used where six or more circuits are employed. The load distribution shall ensure a reasonable current balance between the phases.
Old 06-12-2007, 06:43 PM   #8
tinbender's Avatar
2001 16' Bambi
Talking
HowieE: Oh man, why did I sell those grow lamps at my last yard sale?? Now I actually have the perfect place to use them!! Guess I'll just have to stick to raspberries and tomatoes. Actually, HowieE, I owe you a debt of gratitude. I have not been able to pick a name for my trailer that I really liked. Now I know exactly what it is -- Shinee Blunt -- ..
Markdoane: Thanks for the lesson on balancing the legs of the 50 amp. It made perfect sense and I do have and will probably use all the other items you listed, with the exception of the lamps of course.
Thanks again, TB
Old 06-12-2007, 07:51 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
TB,
Which ever you decide to use....50A/240VAC or 30A/120VAC.....be VERY CERTAIN that your electrician realizes that RV 30 amp circuits are 120VAC and NOT 240VAC. I have seen a couple of RVs that were fried by the owners 30 amp outlet because the electrician assumed that they wanted 240 volts.
Old 06-13-2007, 09:34 AM   #10
HowieE's Avatar
Images: 12
Tinbender
Naming is some times a problem. We lucked out with a less conspicuous name. I had sold some options on Radio Shack and we named our then trailer R Shack and carried the name forward to the Airstream. The only problem the majority of the individuals passing by and reading our sign think our last name is Shack.
Well at least we will know whats in a name if we pass by each other.
2004 Excursion 4x4
Old 06-13-2007, 10:31 AM   #11
1984 31' Sovereign
phoenix , Arizona
Tinbender
On my Flxble the power cord had plugs on both ends, during the night somebody took the cord, I thought the breaker had triped and went back to sleep. Next moring the cord was gone. We spent a half a day in a strange town trying to make a new cord. I put a cable and lock on it.
got diesel is offline   Reply With Quote
Old 06-13-2007, 11:49 AM   #12
Viera , Florida
Copper thief?
Old 06-13-2007, 04:43 PM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Sorry to hear about the cord thieft. They took it while it was in use?
Welcome to the forums. We have a pretty good base of streamers here in the valley of the sun!
Richard
Old 06-22-2007, 03:02 PM   #14
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Wiring for shore power
[quote=lewster]TB,
Which ever you decide to use....50A/240VAC or 30A/120VAC.....be VERY CERTAIN that your electrician realizes that RV 30 amp circuits are 120VAC and NOT 240VAC...
I am planning to set up a 30 amp circuit at home so I can run the A/C when I am working in the Airstream. Everything else should be able to be run on a 20 amp circuit with a 10 gauge extension cord, right? I am looking for some diagrams and parts specs. that would give me an idea of wire gauge, circuit box type, etc.
Thanks in advance,
bill b.
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
powerlines, 30amp vrs 50 amp skip Electrical - Systems, Generators, Batteries & Solar 21 01-22-2004 11:31 PM
Where can I buy 30 amp plugs? Ultradog Electrical - Systems, Generators, Batteries & Solar 8 10-14-2003 05:12 PM
I've got POWER!! Davydd Off Topic Forum 4 09-11-2003 10:55 AM
Roof Air Problams ViewRVs Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Disaster Weekend davidz71 Our Community 11 07-03-2002 04:27 PM
