Old 01-28-2017, 05:00 PM   #15
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
adapter
This may be what you are looking for but kind of expensive.
If not they have just about every variety 50 to 30.
https://www.westmarine.com/buy/marin...99?recordNum=4
Garry
Old 01-28-2017, 05:43 PM   #16
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I purchased a 30 to 50 amp off Amazon, it is a blue one, which is very flexible when cold, I like it...
Old 01-28-2017, 05:50 PM   #17
2015 25' FB Flying Cloud
Meadow Vista , California
I don't see the blue one, do you remember the band name?
SS
SilverSinbad is offline   Reply With Quote
Old 01-28-2017, 10:11 PM   #18
1988 32' Excella
Robbinsville , New Jersey
http://www.campingworld.com/shopping...r-50-amp/81045
This one with a 30AMP extension cord is the way I would go. That and the first dogbone that was posted in case you need both cords for length.
Old 01-29-2017, 06:36 AM   #19
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
SS
Yes, I looked on Amazon again, still in my previous orders,...Vottec. 16-00588, 30- 50 amp, 10/3, 25'. It is blue with yellow ends, it is very flexible and easy to handle when cold.....
Old 01-29-2017, 07:01 AM   #20
2014 27' FB International
Macon , Georgia
Voltec
Roadtech is offline   Reply With Quote
Old 01-29-2017, 07:21 AM   #21
AlanMcD's Avatar
Cincinnati , Ohio
Found this at Home Depot. I think it's exactly what you're looking for. I may run out and buy one.
http://www.homedepot.com/p/Rodale-25...0D25/202669100
-Alan
AlanMcD is offline   Reply With Quote
Old 01-30-2017, 08:07 AM   #22
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
-Alan
That is $50 more money than the blue one from Amazon, and it will be stiff when cold, the blue one from Amazon is very flexible...
Old 01-30-2017, 08:19 AM   #23
Thanks all,
I ordered the blue one from Amazon, better hurry only two left.
Best,
SS
Old 01-30-2017, 03:54 PM   #24
AlanMcD's Avatar
Cincinnati , Ohio
Ah ha, yes, I missed this as I was looking for a link to click. The one you found does look better - flexible and less expensive.
-Alan
Old 02-05-2017, 08:26 AM   #25
Macon , Georgia
Is there a shorter 50 amp to 30 amp cord? I would like to have one about 10 to 12 feet long to use when hooking up a generator.
Old 05-31-2017, 08:12 PM   #26
Kirby , Arkansas
Thanks all. I get what you are saying. I have done house wiring with a myriad of 220 plugs and receptacle, but I am a novice with RV plugs and receptacles.
I am shopping for my first RV and have about decided which AS RV I want. So, I am definitely an "RV Plug Novice." Sales Persons are pretty useless with answers to my questions such as, " a technician will go over every aspect after you buy, and before you pull out of the lot." OK. I hope so, but I would appreciate a little forewarning about some of the little extras that might be needed.
I have seen that the plug end of an AS 50 Amp cable has 4 prongs. I assume the other end that plugs into the trailer has 4 prongs/conductors as well???
I have seen that some camp sites have no 50 amp service, but may have 20 or 30 amp services, which may run my lights, charge the house batteries, and may run a microwave or one A/C.
My question is do the new AS RV's generally just come with one 50 amp service cord/cable, and if I need to plug in to a smaller service or a generator, do I need to furnish an array of adaptors?
DA4753 is offline   Reply With Quote
Old 05-31-2017, 10:19 PM   #27
1979 23' Safari
Wayland , New York
Pretty much you are correct. You'll get a 50amp cord with the trailer. It is wise to carry a 50 amp to 30 amp adapter(dogbone) for the instance where you might find yourself in a campground where you can only get a 30 amp connection. The 50 amp cord plugs into it then the pedestal. They make 15/20 amp adapters as welll, it's not tonlikely you'll need one but it's not expensive insurance just in case. Keep in mind you'll always be limited to lowest connection amperage. So if your 50 amp cord goes through a 30 amp adapter to the pedestal you can only use 30amps. The breaker on the pedestal provides 30 amp protection in this case.
Old 06-01-2017, 02:17 AM   #28
2016 30' International
redondo beach , California
I am using this:
Voltec Industries 16-00588 30-Ampere to 50-Ampere RV Locking 10/3 STW Cord, 25-Feet
Also for even smaller current draws I use a 50 to 20 amp adaptor.
Randy and Beth
2015 F250 Titan 50 gallon tank
2016 International ProPride, EasyStart, Michelin 16", Battle Born LiFePO4 x 2, PD 60 Amp converters x 2, Victron BMV 712, Orion 12/12, and Blue Solar MPPT all in a rolling experiment
Nobody's perfect and I'm a perfect example
mythbuster88 is offline   Reply With Quote
Shore power cord replacement atvmcg Electrical - Systems, Generators, Batteries & Solar 7 03-21-2017 05:55 AM
shore power cord and 12 volt. jpalm1048 Electrical - Systems, Generators, Batteries & Solar 2 09-07-2010 10:46 AM
Trying to replace shore power cord tlavergne Electrical - Systems, Generators, Batteries & Solar 6 08-13-2010 08:51 PM
Shore Power Cord Reel wasagachris Batteries, Univolts, Converters & Inverters 2 06-16-2010 11:28 PM
Shore power cord FreshAir Electrical - Systems, Generators, Batteries & Solar 18 02-21-2007 02:41 PM
