Old 07-10-2014, 05:39 AM   #1
Rawn77's Avatar
Montreal , Quebec
Send a message via Skype™ to Rawn77
50 amp to 30 amp pigtail question
From what I understand a 50 amp RV receptacle has 2 hot wires, 1 neutral and 1 ground. I guess that's why there are 4 prongs on a 50 amp cordset.
So my dumb question is, when you use a 50 to 30 pigtail adapter what happens to one of the 4 wires since a 30 amp cordset has only 3 wires; hot, neutral & ground. Does the pigtail simply discard one of the hots coming from the 50 amp side?
I was just wondering.......
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
Rawn77 is offline   Reply With Quote
Old 07-10-2014, 05:52 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Yep. That's how it works.
I had the same question until I took a meter to our adapter.
This is electricity we're talking about here. There are no dumb questions!
Old 07-10-2014, 05:57 AM   #3
Rawn77's Avatar
Montreal , Quebec
Thanks!
Kind of what I thought
Ron
Montreal, QC
2017 Classic
Honda EU3000
Hensley
Old 07-10-2014, 09:39 AM   #4
Wayward's Avatar
Cary , North Carolina
Maybe I can simplify the background . (or not )
This is an oversimplification because I will omit a few safety/grounding points that might make it harder to understand the basics
There are really only 3 wires coming in to the typical 50/30amp campsite hook up box.
--------------HOT1
--------------Neutral
--------------HOT2
All 110v consumer appliance/devices really only "need" 2 wires to work. Current comes into the appliance via HOT1 and then current flows out of the appliance through the 2nd wire to Neutral. OR Current comes into the appliance via HOT2 and then out to Neutral.
If you have a 30amp setup like most Airstream it is all 110v. In the RV campsite your 30 amp outlet is really only using 2 wires - either HOT1 and Neutral or, HOT2 and Neutral. The third wire in your 30amp plug/cord is for safety/ground.
220v consumer appliance/devices also really only "need" 2 wires to work. You hook 2 wires across HOT1 and HOT2 you get 220v and more current/power.
By bringing all 3 wires into an RV (not most Airstreams) it can run both 220v appliances (HVAC) or 110v appliances and have far more current and power. This 50amp service outlet at the campsite is really only using 3 wires - HOT1, HOT2 and Neutral. The fourth wire in a 50 amp plug/cord is for safety/ground.
To answer your question, YES. The 50-to-30 amp pigtail simply picks up Neutral, the saftey ground wire, and either HOT1 or HOT2. There is no electrical connection to the other Hot wire..
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 07-10-2014, 10:12 AM   #5
Wayward's Avatar
this got me thinking
30amp vs 50amp service is misnamed and causes some of the confusion.
It should be 110v service vs 220v service.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 07-10-2014, 11:06 AM   #6
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
It's both 110 volts. 220 volts will blow your whole wiring system. A friend plugged into 50amp at a FL campground which was wired wrong and, yes cooked the RV wiring. Nothing should be 220 volt in a RV of any kind. Be careful, when in doubt check with an electrician. Don't take casual answers as fact.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-10-2014, 11:19 AM   #7
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The "painfully accurate" (read: nerdy, pedantic) way to describe how it's actually used would be 30A vs 2x50A, since what the 50A receptacle at the pedestal provides to an RV that is set up for 50A is 2 circuits at 120v, each capable of providing 50A. That will probably confuse people even more, though.
"Nominal" supply for most residential and light-commercial applications in the US has been 120 or 240 for a long time, rather than 110/220.
David
Old 07-10-2014, 11:58 AM   #8
Rawn77's Avatar
Montreal , Quebec
So let me add to the confusion:
Does that mean when I hook up the RV with a 50A cordset that only a single 50A 120V is going to the RV?
Ron
Montreal, QC
2017 Classic
Honda EU3000
Hensley
Old 07-10-2014, 12:21 PM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Depends if you're plugging in a 30 Amp trailer or a 50 Amp trailer.
If it's a 30 Amp trailer, and you use a 50 to 30 Amp adapter, then you have a single 50A 120 VAC circuit feeding your trailer. The 30 Main breaker in your trailer will prevent you from pulling more than 30 Amps and frying your shore power cord.
If it's a 50 Amp trailer, then you have two 50 Amp circuits feeding your trailer (the 2 hot wires mentioned previously). The 50 Amp main breaker in your trailer is a dual breaker, and each side feeds half the circuit breaker box. After that, it's up to the trailer manufacture to determine what circuits run on which half on the breaker box. A typical distribution would be to have one a/c unit in each half of the breaker box. Then other circuits are spread out however they see fit.
Chris
Old 07-10-2014, 12:28 PM   #10
Rawn77's Avatar
Montreal , Quebec
--------------HOT1
--------------HOT2
More questions, please don't shoot me:
At the pedestal for 50A service, there's 2 HOTs, 1 Neutral and maybe 1 Ground??
So if I was theoretically to create my own 50A -> 30A Pigtail, I wouldn't have to worry which of the 50A HOTs to discard or are there times at the pedestal that only one of the two 50A HOTS are used?
It would seem that after reading all of the above comments that there are two 50A-100V HOTS at the 50A receptacle on the pedestal but that only one of them is ever used. Then why is it there? Especially if no one is combining the two to create a 240V connection.
Ron
Montreal, QC
2017 Classic
Honda EU3000
Hensley
Old 07-10-2014, 12:30 PM   #11
Rawn77's Avatar
Montreal , Quebec
Chris
Thanks Chris
You've explained everything!
I feel much better now.... I'll sleep tonight
Ron
Montreal, QC
2017 Classic
Honda EU3000
Hensley
Old 07-10-2014, 12:50 PM   #12
Minno's Avatar
1972 31' Sovereign
Shooting is not allowed... Like someone else said, this is electricity. No dumb questions. better to be safe than zapped.
No maybe on the ground - it's there. The ground, is literally that. It's connected to a ground rod somewhere. If not at the campsite post, then wherever the main circuit panel that feeds the campground is located. The ground rod is a 10 foot copper rod that's pounded into the ground, and provides a safety for the electrical service, each RV, each appliance, and you.
If you make your own adapter, you are correct. Pick one of the 50 Amp hots (black) to connect to the 30 Amp hot (black). Simply do not connect anything to the other 50 Amp hot in the 50 Amp plug. Be sure to connect neutral to neutral (white) and ground to ground (green). Since this is providing 30 Amp service, use at least 10 Gauge wire.
Chris
Old 07-10-2014, 01:00 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Many 240 volt appliance require the neutral as well as 2 hot legs. The light inside a dryer is 120 volts as well as the motor that rotates the drum. The heating element in most dryers is 240 volt. The controls are low voltage requiring 120 volts.
Old 07-10-2014, 01:19 PM   #14
Rawn77's Avatar
Montreal , Quebec
Chris
Help me understand something:
If I'm trying to adapt a 30A RV to a 50A pedestal, dropping one of the 50A HOT's makes sense if I'm making my own pigtail.
But, if I'm connecting my 50A RV to a 30A pedestal with a pigtail, wouldn't I need the single 30A HOT to connect (or perhaps better to say...split) to both 50A HOTs in the pigtail?
Look at this cordset from Park Power
If the 50A RV indeed has two sides to it's circuits, the 30A single HOT wire would have to feed both sides, correct?
How do you think the above cordset is wired at the female end?
Ron
Montreal, QC
2017 Classic
Honda EU3000
Hensley
1974 Sovereign 12 volt battery pigtail Shamock Batteries, Univolts, Converters & Inverters 3 06-24-2011 05:08 PM
New Pigtail locks up my Sovereign brakes mello mike Electrical - Systems, Generators, Batteries & Solar 15 08-14-2009 10:46 AM
It all worked before I redid the pigtail 72BamaStream Electrical - Systems, Generators, Batteries & Solar 5 01-20-2009 08:17 AM
73 Safari - Need Electrical Pigtail Between Vehicles kadyacres Electrical - Systems, Generators, Batteries & Solar 5 07-05-2004 01:10 PM
'72 Trade Wind Pigtail Schematic igor Brakes & Brake Controllers 3 07-14-2002 03:15 AM
